Latest post 12-05-2011 5:24 PM by Sam. 14 replies.
Page 1 of 1 (15 items)
  • 08-05-2011 2:11 PM
    • Sam
    • Not Ranked
    • Joined on 08-24-2010
    • Rugby, UK
    • Posts 14
    • Gold Member
    Beogram 8000 Solenoid :(
    Hi all,
    Currently working on an BG 8000, with a non-dropping tonearm issue. After much ado with getting new drive belts for the tonearm spindle drive, a good lubrication, and performing all the adjustments in the service manual, there is now a voltage across the coil (or so it seemed). There is still no drop of the tonearm!!
    At this point a manual push of the solenoid would allow the normal and fully correct operation of the turntable - but I don't want to have to sit with a screwdriver in my hands while balancing the lever to listen!!!!
    So, measuring the resistance of the solenoid gave me infinity. Bad news, (should normally be zero).
    Out came the solenoid, and it was inspected to find that one of the coil wires (where it emerges from the main coil), was broken before making it to the cable/enamelled? wire connection :(
    See pic Below:
    Broken Coil Wire PNG
    C
    The Cursour shows the location of the break!
    (Apologies for poor screenshot image, I have no image editor on this PC)
    So basically, I'm looking for ideas.
    Given the macroscopic size of the solenoid itself, and its delicate construction, I'm nervous in attempting a fix. The glue used to insulate, and hold the wires in place is pretty much permenant, and I can't really scrape through it.
    Hmmmm.
    Thanks for any helpful comments?!?!
    Sam
  • 08-06-2011 2:37 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 8000 Solenoid :(
    Sam,
    Great fault-finding !
    I will see if I can find a good solenoid.
    Got your PM as well and I will answer that asap.
  • 08-06-2011 8:20 AM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    I'm pretty sure Martin will find you a coil !
    This is in fact like a small speaker or microphone without a cone or dome, and I have repaired many, often tweeters, by just pulling one turn of wire and resoldering/reglueing it to the alu foil with special varnish.
    But you'll need a 15W iron and a steady hand!
    Jacques
  • 08-06-2011 10:40 AM In reply to
    • Sam
    • Not Ranked
    • Rugby, UK
    • Posts 14
    • Gold Member
    Hi, and thanks for the encouragement for a fix!
    Im not expecting to be successful with this, but its worth having a go.
    My soldering iron is adjustable, so I'll put it on the lowest temperature to try.
    I will report back with results!
  • 08-06-2011 10:54 AM In reply to
    Sam:
    We love pics
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 08-06-2011 6:07 PM In reply to
    • Step1
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I personally think that is repairable Sam, This was quite a challange but quite doable...
    Olly.
  • 08-06-2011 6:12 PM In reply to
    Hat of for Olly
  • 08-10-2011 12:26 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Thjought I did ok considering a normal 3mm soldering iron tip was used :-)
    Olly.
  • 11-27-2011 4:11 PM In reply to
    • Sam
    • Not Ranked
    • Rugby, UK
    • Posts 14
    • Gold Member
    Hi guys,
    Sorry this reply has taken so long! I completed the fix months ago, but only just got roung to posting :S
    Anyway, one turn of wire off, and resoldered OK first time round:
    Resoldered
    but I must have damaged the wire in between soldering (after which I measured the resistance) and installing, So it all had to come back out, get a fresh bit of wire (just some 7x0.12mm I had lying around):
    New wire
    Yeah, OK, that wire is a bit of overkill, but will do for now.
    This beogram is destined for new caps soon (on the to do list) so I can order something better when that all gets done.
    Plugged in, test MMC on the arm and test vinyl on the platter. When that arm dropped! Boy did it feel good. Finally!!
    tonearm dropping
    Now I have an MMC20CL, but have never listened to it, for lack of a deck worthy of such riches.
    So, I can now comment on how crisp and clear this stylus sounds. Definately worth the extra!
    It just makes all the instruments have a depth deeper than I've ever heard on vinyl!
    (Hope theres enough pics for you guys) Stick out tongue
  • 11-27-2011 6:27 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Brilliant Yes -  thumbs up
    Olly.
  • 11-27-2011 7:57 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Well done, Sam!  Beer
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 11-28-2011 2:39 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    I just knew you could do it!
    Congrats!
    Just one question: how long does it take for the cartridge to drop?
    Jacques
  • 12-05-2011 4:01 PM In reply to
    • Sam
    • Not Ranked
    • Rugby, UK
    • Posts 14
    • Gold Member
    Wow, thanks for the comments guys!
    Chartz - As the arm gets to the correct place on the record, theres a very short (very) before the needle drops. However, it is quite a harsh drop, so I'm hoping a cap replace will assist this?
    Theres a bit of elastic in the tonearm spindle, but I have replaced the belt which has semi solved the problem, but a full clean and lubrication will be done when the caps come out.
    Cheers!
  • 12-05-2011 4:17 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Sam:
    You may want to read this.
  • 12-05-2011 5:24 PM In reply to
    • Sam
    • Not Ranked
    • Rugby, UK
    • Posts 14
    • Gold Member
    Interesting. Next time this is open I'll have a play around in there.
    Interesting that component replacements can't correct this.
    Do you think it has something to do with the leaf spring in the tonearm assembly? It could relax over time and loose some of its pre-stressing. This could give these unsmooth tonearm lowerings.
    Just a thought. Please prove me incorrect!
