Latest post 08-09-2011 8:20 AM by joeyboygolf. 6 replies.
Page 1 of 1 (7 items)
  • 08-04-2011 2:52 PM
    Someone switched the light out!
    I have a Beolink 7000 remote which appears to work now that I have replaced the battery pack.
    I say appears to work because the blue light is out on the upper display/keyboard.
    The legends can just be seen on careful inspection and the remote seems to function as it should.
    Anyone help?
    Regards Graham
  • 08-06-2011 7:23 PM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    Re: Someone switched the light out!
    The backlight is an electroluminescent panel in BL7000, and they can stop working. Check for ~120V AC at the two wires which feed the backlight sheet. If the voltage is present, then the EL material has failed.
    It can be purchased either from RS or from china via ebay, or elsewhere.
    http://newzealand.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2678784
    http://cgi.ebay.com/A6-electroluminescent-panel-sheet-foil-EL-back-light-/380359298268?pt=LH_DefaultDomain_0&hash=item588f2e4cdc
    The sheet is cut to size, and the display comes apart easily enough to allow the old backlight sheet to be replaced. Just be patient, take your time and be careful not to get any dust in there!
  • 08-07-2011 6:29 AM In reply to
    Many thanks Cozza, watch this space!
    Regards Graham
  • 08-07-2011 9:25 AM In reply to
    No 120v present so will investigate on the lower board under the polished panel.
    Any further help would be appreciated.
    Die_Bogener has told me that there are some transistors and a couple of diodes associated with the inverter which will need looking at.
    Regards Graham
  • 08-07-2011 12:26 PM In reply to
    Here are the transistors, the three mounted on the alumenum cooler. The mid one is for the powersupply of the cpu, the outer ones for the 110V AC supply.
    BD435 and BD436
  • 08-07-2011 2:51 PM In reply to
    Brilliant!
    I'll order some in.
    I'll be back in a couple of days, or so.
    Regards Graham
  • 08-09-2011 8:20 AM In reply to
    I have replaced the two outer transistors and still no 120vAC
    Any ideas would be appreciated as I am working in the dark here?
    Regards Graham
