1st March February 2012
Latest post 09-05-2011 4:57 PM by sergi0. 47 replies.
moxxey
![](/utility/anonymous.gif)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Just seen the BV7-55 3D at my dealer and was impressed. They had a 3D demo of the universe and the depth was amazing.
Only problem is, once I took the glasses off, my eyes still haven't fully readjusted. I don't know if I could watch 3D very often and I can't see me wearing those glasses to watch 3D football!
It is huge though. Felt very cineramic. I can't see 3D working too well on the 40". You need to 55" to get the depth.
The standard HD picture on that 55" is better than my BV7-40, for sure. Colours seem richer.
Hungedu
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.32.82/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 08-08-2009
- Ambergris Caye, Belize
- Posts 128
3D Glasses that are compatible with BV 7-55?
Does anyone out there have any idea of which glasses might work with this TV? They are available through B&O for about $200 each, but I'm sure there are Samsung ones out there for a lot less that are compatible with the 7-55. I just don't want to spend $200 per pair of glasses that one of my friend's' kids are going to drop on the floor and break.
BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
f5434964
- Joined on 07-21-2010
- Posts 198
Re: 3D Glasses that are compatible with BV 7-55?
be aware if B&O uses shutter technic the glasses will have to correspond with your TV - and I can not imagine any company that wouldn't use their special frequency to assure only their own glasses are working...
regards elmar
mawheele
- Joined on 12-05-2007
- Posts 82
I noticed recently that the industry players are looking to standardise glasses specifications for 2012 models.
mawheele
- Posts 82
Quick question for people with the new TV. What version of the BS3 firmware is installed on the TV?
Daniel
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.24.49/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Hungedu:
These are not that expensive and they are hard to break. ![Big Smile](http://forum.beoworld.org/emoticons/02.gif)
Hungedu
- Posts 128
I'll buy one dozen!
Griebel
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.75.00/avatar.jpg)
- Joined on 03-09-2008
- Posts 122
Just got my BV 7-55" 3D. The first one sold and delivered in France! It's worth a picture ![Smile](http://forum.beoworld.org/emoticons/01.gif)
Will try to write a review after the first tests.
Cheers.
MikaelB
- Herning, Denmark
- Posts 191
What differences are there from 7-55 MKI to MKII (3D)?
This is what I have found out till now:
- 3D
- Local dimming in smaller squeares
Any other?
/MikaelB
moxxey
- South West, UK
- Posts 2,360
Griebel:
Looking at the size of the 6000s next to the BV7-55, you realise how big the BV7-55 is.
My dealer's arrived when I was in store and, no kidding, you could fit a small car in the palleted box. I have no idea how they got it in to the store. It was so heavy I couldn't even move it along the floor, myself!
sergi0
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.73.80/avatar.jpg)
- Joined on 03-06-2011
- Posts 99
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Hi Folks,
I just came back from my B&O dealer in order to give a look at the new 7-55 3D. I was surprise to notice a design difference between the 2D and 3D model.
The BR tray is the same size on both, but not the bottom alu frame. In the 2D version, they have the same height, but with the 3D, the bottom alu frame is bigger. You can see it slightly on Griebel's pictures. At first it was not noticeable, but after some time, you can spot this absence of "alignement" in the general shape.
well, it is strange. What's your opinion?
Sergio
Griebel
- Posts 122
Right, of 1,4 cm (0,55 in).
sergi0
- Posts 99
strange. is it for a special purpose or just a change in design?
Daniel
- Svinarp, Sweden
- Posts 1,284
The 3D BR drive used is bigger than the old one without 3D.
sergi0
- Posts 99
it is a little bit lame to have to make a bigger frame just to host a bigger BR drive. I must say I am disapointed.
Hungedu
- Posts 128
I haven't really noticed that on mine.
Razlaw
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.28.75/avatar.jpg)
- Joined on 04-24-2007
- Illinois
- Posts 1,770
![Silver Member](/Themes/beotheme1/images/roleicons/3cca3820-1e81-47d8-9399-96612b7eabf0.gif)
New video of the BV7 on the B and O site. It shows very clearly the difference in size of the frame and the tray.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
symmes
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
- Joined on 04-21-2007
- Freedonia
- Posts 290
sergi0:
I would hope you would give a little grace on that one, because you surely wouldn't spend that kind of development money if you didn't have to, right?
sergi0
- Posts 99
Maybe, but the alignement was clearly a design choice, and the new one is not. my guess is that if the BR was not so big, the frame wouldn't have be bigger... the design of this particular pieces does not look as balanced as previously.
I am a little picky on this one as I was planning the buy this TV. and clearly I will have prefer an internal hard drive rather than a useless bigger frame ;)
symmes
- Freedonia
- Posts 290
sergi0:
Fair point. Maybe the TV without the BD at all is a better option?
sergi0
- Posts 99
I was asking about it for the 2D version and the small extension of the BR was still here... plus that for a 3D TV, I would appreciate to have a BR 3D integrated...
I admit I am a little bit complicated ;)
