I am wondering if anyone has ever wanted to have a good reel to reel tape recorder connected to their Beosystem, and then worked on how to control it remotely via Beosystems Datalink ?
There has been some discussions on deciphering the Datalink protocol and building a controller device based on some or other microprocessor from scratch, but isn't there an easier way: stripping microprocessor board and other Datalink components out of an old "donor" Beocord and attaching them to some relay controlled tape recorder ?
Take e.g. some Beocord 5000/5500 type machine which has already relays operating the cassette mechanism and wire these to a reel to reel machine. In its simplest form only play, stop, rec, rewind and ff are needed to make a completely working system. Also, it should be quite easy to wire tape recorders operating switches to the Beocords microprocessor board to provide two-way operation as well.
Any thoughts on that ? Has anyone tried something like that and with what results ?
-jari
