1st March February 2012
Latest post 08-03-2011 9:24 PM by Razlaw. 4 replies.
08-02-2011 2:17 AM
LarsH
- Joined on 06-23-2007
- Uppsala, Sweden
- Posts 42
MOTS Seeder disabled wigth new BS5 SW update...
Hi All!
I have now discovered and verieifed that the MOTS Seeder doesn't work after the software update of BeoSound 5.
Pressing Go on the Beo4 remote when hearing a song does not seed that song for MOTS...The only way is to go into the screen, open up the album, select the song and start from that song...
Is there anyone that has a solution for this, or do we have to wait for B&O to release a fix?
Best Regards, Lars
___________________________________________________________________ BeoVision 7-40 MkIII, BeoSound 5, BeoLab 9, BeoLab 4, BeoVision 3-32, MX 7000, Beo4*3, BeoCom 2, BeoCom 5
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Re: MOTS Seeder disabled wigth new BS5 SW update...
I am not very familiar with MOTS as I do not use it. I just tried it on my 5 however. I pressed GO and seemed to work. It played a series of songs that all seemed similar. Also, the MOTS symbol appears. Have you tried adding MOTS to the list function on the Beo and activating it with that?
Also, I think there is a setting in the Beosound 5 to disable MOTS. Perhaps that has been changed?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
LarsH
- Uppsala, Sweden
- Posts 42
Well, MOTS works if I start it from the BeoSound5 and select a track...
15 tracks later, I want to have that track as the seeder, and press Go --->>> and the seed function doesn't work...
hmmm....
Razlaw
- Illinois
- Posts 1,770
Strange. I will try to play with mine some more. Sorry that I have not used MOTS much. I am sure there are others here who know more than me, but mine seems to be working fine.
Razlaw
- Illinois
- Posts 1,770
I started the Beosound and activated MOTS. I let it run for a couple of hours. Activated MOTS again from the Beo 4 and seemed to work again, except a few minutes later I noticed the cover art did not match the music playing.
Page 1 of 1 (5 items)
