Latest post 08-05-2011 9:06 AM by deaddruid. 4 replies.
Page 1 of 1 (5 items)
  • 08-01-2011 3:34 PM
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    MasterLink control of PVR
    I have a Humax 9200 Digital Terrestrial receiver connected to an Avant with STB-C, and I can select programmes on this from a MasterLinked MX4002. However, the Humax includes a hard disk, in order to record programmes. To play these recordings on the Avant, I have to select <MENU><1> and can then get access to the Humax menu system.
    Can anyone advise me how to play recordings on the Humax, when controlling it from the MX4002? When I press <MENU> it selects the MX4002 menu, and I cannot find a way to reach the Humax menu.
    Thank you in advance.
    Mark
    Filed under: ,
  • 08-01-2011 3:41 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: MasterLink control of PVR
    The side bar menu is generated by the STBc software inside the Avant and will not appear on a TV in a link room.
    You can still get control of the box by using a shortcut. Make a note of the numbers on your side bar e.g. if menu is number 1,  In the link room just select the Humax box then press "GO + 1". This should work for all boxes controlled in the main room with STB.
    This principle also applies in the main room. Even though you have access to the side bar menu, it's just as quick to press GO = XX to get to whichever command you want.
    Opman
  • 08-03-2011 1:51 PM In reply to
    • deaddruid
    • Posts 247
    Works beautifully - thank you for the solution.
    Mark
  • 08-03-2011 6:02 PM In reply to
    • kai
    • Joined on 11-16-2008
    • Posts 81
    From memory all you need to do is prefix the command with go. If you look at the guide that comes up on the left hand side of the avant each command has a number, so you would press go 1 etc :)
  • 08-05-2011 9:06 AM In reply to
    • deaddruid
    • Posts 247
    Hmm... something a little odd.
    Sometimes, <go> <1> works. Sometimes, <go> brings up the programme list, such that <go> <1> selects channel 1. I haven't yet worked out what causes the different behaviour.
    Mark
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
