Latest post 08-02-2011 8:54 AM by Hiort. 9 replies.
Page 1 of 1 (10 items)
  • 07-31-2011 3:11 AM
    Anti Reflection screen
    I'm planning to buy a BeoVision 10-46 in a few months time, but I'm not quite sure whether to get the Anti Reflective screen with it or not. Does anyone of you have any experience with it, and do you think it's worth the money?
    /JJ
    BeoLab 3, BeoCom 5, BeoSound 8, A8, EarSet 3i
  • 07-31-2011 8:06 AM In reply to
    Re: Anti Reflection screen
    Get the ar, and be sure to buy/learn its proper care and care products.
    B
  • 07-31-2011 8:44 AM In reply to
    My dealer replaced my Beovision 10-46 for the AR version.
    It was far to bright in my livingroom. (see: Flash your B&O for pics, thats the new AR)
    I think the AR version is simular to my old Beovision 7-32 screen.
    Beware: the screen when it is off it has a slightly blue / purple haze (Is that the correct word?)
    The normal screen is completely black.
    Jasper, The Netherlands
  • 08-01-2011 2:14 PM In reply to
    • Style
    • Not Ranked
    • Joined on 08-01-2011
    • Posts 40
    Unless you have a very dark room it's a must have.
  • 08-01-2011 2:58 PM In reply to
    Thanks for the replys. You seem to think that the AR option is worth the extra money. I was thinking that most of my TV viewing takes place at night when it's getting dark outside, but I may have to reconsider.
    Jasper, is that the AR version pictured in the "Flash your B&O"-thread?
  • 08-01-2011 3:11 PM In reply to
    Jan Johansson:
    Yes it is
  • 08-02-2011 2:53 AM In reply to
    • jahur
    • Top 500 Contributor
    • Joined on 02-07-2011
    • planet zonk
    • Posts 161
    get the tv fully loaded, not only does it enhance resale value an AR screen is worth it through and through...
    (formerly nokinnikon from the old site)
  • 08-02-2011 4:46 AM In reply to
    I do not have the AR screen, and I regret I did not purchase it but I did not have the budget at the time.
    Have got a price for doing a retrofit and considering a change of the glass screen.
    It´s a quite straight forward process mechanically, but the picture needs some adjustments afterwards.
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 08-02-2011 5:42 AM In reply to
    Could you perhaps compare the AR/non-AR version to the matte/glossy screen on a MacBook Pro?
  • 08-02-2011 8:54 AM In reply to
    Jan Johansson:
    Not really.....
    Screen is still glossy but reflexions are less obvious.
    Suggest you visit a dealer to see for your selves.
    _____________
