nmartin771:
tournedos:Therefore, using class D for the higher
frequencies as well would add a lot of cost and technical difficulties
with practically no benefits.
Interesting, what about 5's then ?
Even the mid and treble amps are much bigger in the 5s, so I believe
it is already a question of practical implementation issues... if it
needed two uncompromised quality 250W conventional amps in addition to
what is already in there, I think you would need a fork truck to move
them around, and the amount of generated heat would be too much.
nmartin771:Is there any down sides with this setting D+AB ?
None really. They are matched together and it's not an issue at the listener end
