1st March February 2012
Latest post 02-28-2012 2:31 AM by Fisp. 57 replies.
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Re: What iphone app is the best for BS5/BM5?
Looks like an interesting App. But, priced very high. Anybody else have any experience with it?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
andriani
- Joined on 05-24-2008
- Posts 47
RAZLAW
i have try to put server musicat yes and i see on elyric beomaster in both renderer and serveur thanks!
For UPNP SONGBOOK sorry i haven t tried
Razlaw
- Illinois
- Posts 1,770
andriani:
RAZLAW
You are welcome. Glad I was able to help.
gysse2004
- Joined on 05-19-2009
- Copenhagen North
- Posts 42
Has anybody had this problem, when you put a song on ie. Elyric - Beomaster 5 =Renderer , Media Server = BeoMaster 5 it only
plays on song, playlist funktion dosent work ( MOTS) etc.
Peter
Razlaw
- Illinois
- Posts 1,770
Yes, I do not think MOTS and the BS 5 playlists work with eLyric. I think you have to create new playlists within eLyric.
koert2
- Joined on 01-08-2011
- Posts 4
Hi, does this IPAD integration also work if you only have the BM5 (connected to BV7)? Or do you need the BS5?
Thanks,
Koert
Gustave
- Joined on 09-04-2009
- Posts 3
Gustave:
Hello B&O users,
I ended up here also to find answers on why my iPhone4/iPad2 app [ UPNP Songbook '11 ] doesn't see my Beomaster 5! And so I posted here. This post might be one answer to your question abour what App is best to use with BS5. My B&O dealer has UPNP Songbook '11 running flawlesly with his BS5. With me it's a bit unstable I still don't know why. Could be that I have my BM5 hooked to my LAN via a Devolo AV500 powerplug. Still trying to figure it out.
Cheerio!
[Update:]
I noticed that when the BM5 is set to audiomaster both the server and the renderer are operational and are seen by Songbook. And this way it makes the software work. When audiomaster is set to off the renderer dissapears and the software stops functioning. Music server is on of course.
gysse2004
- Copenhagen North
- Posts 42
Thanks Razlaw, it dosen't matter, the playlist in Elyric is not working either..I put one song on, it playes that - and that is the end of it. strange if you dont have that problem.
peter
Razlaw
- Illinois
- Posts 1,770
I may have the problem also. I have not spent much time with the playlists. I am traveling at present or I would go try it and see if it worked or not.
Peterbs81
- Joined on 07-28-2011
- Posts 6
Playlists is working perfectly in PlugPlayer. I Foundation out it is a heavy app, so shut down other AppS before running it.
gysse2004
- Copenhagen North
- Posts 42
I have tryied alot of the players, 8player,imediacontrol, Elyric, playlist is not working - it playes one number and that is it ?
Anybody ???
koning
- Joined on 04-16-2007
- Netherlands
- Posts 2,670
StUrrock:
Where is the B&O app?
I'm wondering if it would be in the pipe-line a B&O app?
Razlaw
- Illinois
- Posts 1,770
I just noticed that with 8Player it is possible to see what format the music is in. Select a track a press the track witjout releasing it and a menu will appear. It will then display flac for instance.
Griebel
- Joined on 03-09-2008
- Posts 122
How do you configure your system BS5/BM5 + BV7 to make eLyric power on the speakers? I didn't succeed so far. eLyric turns BS5/BM5 on, starts playing... but the speakers don't turn on. What's your setting?
I have also tried several Apps and my rank order would be eLyric > PlugPlayer > iMediacontrol (free!) > 8Player (not easy to navigate) > Twonky (the worst with bad cover art and the issue of not leaving the PAUSE mode, which makes the App completely useless!)
We're still waiting for a B&O Apps...
Razlaw
- Illinois
- Posts 1,770
I did not do anything special. Just connected it and when I tried it, it caused the system to turn on.
kai
- Joined on 11-16-2008
- Posts 81
Easing this with interest are moat people on here happy with elyric, reason for asking my freind has a bs5 and I notice he can turn on the server on it but, before he purchases the app just want to be sure, unless b/o are going to launch one shortly, dealer conference is on in the uk at moment!!
mjmedlo
- Joined on 06-07-2008
- Arkansas, USA
- Posts 384
Razlaw... Do you have speakers directly connected to your bs5? Also, what type of router do you use?
I'm ready for something new that I actually want to buy!
Razlaw
- Illinois
- Posts 1,770
I am using an Apple router. No speakers connected to the BM5. Speakers are connected to a BV 10 and BV 7. BM5/BS5 is connected to an Airport Express.
mjmedlo
- Arkansas, USA
- Posts 384
I finally got this to work the program crashed on me several times though Are you using it to stream music from the iPad or are you just controlling the bm5 with the program?
Razlaw
- Illinois
- Posts 1,770
I just use it to control, although it is not working very well for some reason. I do not stream as all the music on the iPad is also on the Beosound.
I did play around a little today with UPNP Songbook Lite. It has radio on it. When selecting one of the radio stations it displayed cover art for the radio station on both the iPad and the Beosound 5. I could not get any audio, but I think that is because I need to register for the radio service, which I think is free.
mjmedlo
- Arkansas, USA
- Posts 384
Have you tried media connect? I find it to be pretty reliable ... To control the bs5. Streaming seems to be the difficult part of these programs MJM
Razlaw
- Illinois
- Posts 1,770
I have tried it but did not like it.
elephant
- Melbourne, Australia
- Posts 2,215
Razlaw:I have tried it but did not like it.
so far NONE of the free apps mentioned in this thread have rocked my boat :-(
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
Razlaw
- Illinois
- Posts 1,770
And none of the paid apps either.
