Latest post 07-29-2011 3:23 PM by halid. 4 replies.
Page 1 of 1 (5 items)
  • 07-27-2011 10:16 AM
    • cyborg
    • Not Ranked
    • Joined on 07-27-2011
    • Posts 3
    AppleTV 2 and Beovision 8 - 32"
    Dear Forum,
    Thank you for reading my message. This is my first message.
    I have bought recently an AppleTV 2 which I want to connect to my Beovision 8 32", but when I connected it to the HDMI port (the only the TV has) I can't make it to work... simply I don't know how to select it using my BEO4 or configure it (if needed)
    Can you guys help?
    Thank you a lot,
    Cyborg
  • 07-27-2011 10:27 AM In reply to
    Re: AppleTV 2 and Beovision 8 - 32"
    Hi Cyborg, it shouldnt be a problem at all. My settings are in swedish, but I hope I can help. I have a 8-32 myself and I have set the Apple TV on connection 2 so maybe we just copy my settings.
    Start the TV, then press Menu, and then choose Connections (or press 3 on the remote). In the submenu you can choose connection 2, and set the source to DVD, and change HDMI to "Yes". Then press Save.
    Exit all menus. If you now press DVD on your Beo 4 the picture from your nice little Apple TV should appear. You can also attach an IR-cable and control the ATV with your Beo 4, really nice... :-)
    Best regards
    Hans
  • 07-27-2011 10:38 AM In reply to
    • cyborg
    • Not Ranked
    • Posts 3
    Thank you Hans for your quick reply! At least I know is possible now.
    I read the manual and it said:
    HDMI: (High Definition Multimedia Interface) to be used in conjunction with an AV socket. For connection of an HDMI video source or a PC.
    which really confused me a lot as I couldn't make it to work on AV1 initially. I'll now copy your settings and will let you know once I try out.
    Thank you a lot and best regards,
    Cyborg
  • 07-28-2011 9:37 AM In reply to
    • cyborg
    • Not Ranked
    • Posts 3
    Hi Hans,
    This is just to confim that it worked perfectly! Thank you for your help!
    All the best,
    Cyborg
  • 07-29-2011 3:23 PM In reply to
    No problem cyborg, just glad I could help. BR Hans
