Latest post 07-27-2011 7:02 AM by elephant. 7 replies.
Page 1 of 1 (8 items)
  • 07-26-2011 5:54 AM
    Beoplayer doubles Music files?
    I just installed newest Beoplayer on my Dell WinXP Notebook and die a SCAn in the n.music source. Runs quickly through my C-drive and finishes without any problem.
    But when I looked into the Album list I saw some Albums doubled and ALL songs within the Albums doubled. Prior to the SCAN I did delete all double files in iTunes and also the files starting with "._" that were in many folders...
    What did I do wrong that the songs are doubled??
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 07-26-2011 7:58 AM In reply to
    Re: Beoplayer doubles Music files?
    Hi, I have exactly the same issue at work on my PC running with Windows 7, all NMUSIC tracks are doubled..but I can't even run a manual scan for the folders..tried re-installing the software, but no change.Hmm
    Reunion Island is greeting you!
  • 07-26-2011 8:14 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Maybe takes .mp3 files and .m3u (playlist files) so every track is there twice?
    Just a guess...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 07-26-2011 8:27 AM In reply to
    thanks Ralf for the hint, but I do not have any m3u files on my harddisk.
  • 07-26-2011 10:35 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Play a title of an album that has been "doubled",
    select "info" the last line "location" tells the path of this file,
    repeat procedure on the 2nd album to see if the the path is identical or different.
  • 07-26-2011 11:59 AM In reply to
    Do the album artist and the track artist match in the tag's
  • 07-27-2011 2:37 AM In reply to
    Good Morning,
    With your help I found the mistake. In the Folder iTunes (already containing all the music files) there was a second folder "iTunes Music" with the doubled music files.
    Strange that iTunes created at any stage doubled directories...
    Thanks again.
    Heribert
  • 07-27-2011 7:02 AM In reply to
    Heribert:
    There is an iTunes import option where you can chose to have the music copied into iTunes' library space, or just use iTunes to manage the meta-data about the music.  Go to preferences and then look in this tab:
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
