Normal
0
false
false
false
EN-US
X-NONE
X-NONE
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-qformat:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin-top:0in;
mso-para-margin-right:0in;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0in;
line-height:115%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:"Times New Roman";
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;}
I don't know what all that crap is above my post but I can't get it to go away. Looks like CSS code. Anways, my post starts below:
I spent the last 12 hours disassembling and reassembling this table trying to fix a few tonearm issues and found it remarkable that not one of those times had I broken anything. Well this last time I reassembled it, there was no audio output. I could hear the output engaging and disengaging (a subtle pop noise through my speakers) as the arm drops and raises so I disassembled the table yet again and found that 3 wires had ripped from the solder joints on the omron audio output PCB. If it helps at all, the model is Omron G2V-2 12 VDC.
I guess what I came here to find is either a wiring diagram, a picture of an already-wired PCB, or some other clue as to which wires go where.
Thank you to anyone to responds.
