Latest post 07-25-2011 12:18 PM by Chrisreunion. 2 replies.
Page 1 of 1 (3 items)
  • 07-24-2011 12:05 PM
    • ReneB
    • Not Ranked
    • Joined on 04-22-2007
    • Posts 20
    • Silver Member
    has Beolab 5 improved since 2004 ?
    Is a 2011 Beolab 5 technically still fully equal to the first versions, i.e. say a Beolab 5 from 2004 ??
    reason for asking: I'm in doubt to keep on saving for a pair or to purchase a Second Life set and save some 6 to 8000 Euro's.
    thanks, Rene
    Filed under:
  • 07-24-2011 4:48 PM In reply to
    Re: has Beolab 5 improved since 2004 ?
    There have been some updates but these are essentially minor. The very first has some issues with syncronising volume when used with a digital feed, but there is a work around - these will be models from before April 2004. There have been a few changes since but nothing very important - a new mains socket was fitted at one point!!
  • 07-25-2011 12:18 PM In reply to
    I think the only pioneering improvement on the Lab 5 (which is -technically- virtually perfect) would be the implementation of a real-time ABC, like the Visionclear system for TVs: every time you open a door, close a window or draw the curtains, the bass level readjusts itself within seconds, instead of calibrating the speaker only on customer's demand by pressing the top plate.
    That should keep B&O engineers busy for a few months I think..Big Smile
    Reunion Island is greeting you!
