Latest post 07-27-2011 3:47 AM by bayerische. 16 replies.
Page 1 of 1 (17 items)
  • 07-24-2011 11:12 AM
    Beolab 8000 & BL 5000 installation
    Hi guys,
    Just wanted to share some of my new speakers at my restaurant Albatros.
    Enjoy.
    First BL8000;
    The metal bases has been removed, and the speakers are bolted through the wooden shelf. (using the original bolt that was fastened to the metal base)
    Second minty BL5000.
    I had custom brackets made, so that they are fastened to the wooden pillars instead of the wall.
    Thanks for looking!
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 07-24-2011 11:20 AM In reply to
    Re: Beolab 8000 & BL 5000 installation
    Brilliant Smile The BL5000 bracket is clever!
    If you ever feel a need to improve something, I would route the cabling of the BL5000s up behind the speakers, then to the side and down along the pillars - that way you could move the white cable channels away from the stone wall.
    -mika
  • 07-24-2011 11:49 AM In reply to
    tournedos:
    Agree with Mika, but a perfect place for the 5000s, and I love the 8000s way up there, just beautiful, congratulations.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 07-24-2011 2:58 PM In reply to
    Fantastic Andreas. Cool I like the way you mounted the 8000's to the shelf with the original bolt. Yes -  thumbs up Also clever use of the pillars instead of the wall for mounting the 5000's.
  • 07-25-2011 4:55 AM In reply to
    tournedos:
    Yep, and use black cables; then as soon as they reach the left resp. right white pole mount the cable channels to the white pillar instead; they will be more hidden...
       Gunther
  • 07-25-2011 3:55 PM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Wonderful, a restaurant I would place a lot of tip in, no matter how the food tastes! Drinks
  • 07-25-2011 4:01 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Andreas, that is impressive! Those 8000s look great on top of the bar, but those 5000s look absolutely stunning!!!! WOW. Surprise
    Evan
  • 07-25-2011 5:55 PM In reply to
    Evan:
    Thank you Evan!
    -Andreas
  • 07-25-2011 5:56 PM In reply to
    Well you are right about the wire covers, I'll change them at some point.
    Yes -  thumbs up
    -Andreas
  • 07-26-2011 10:29 AM In reply to
    Aren't the BL5000 the wrong way round?
    Same issue I have with mine, shouldn't the 'speaker' side of the unit be in the middle and not on the outside?
    Train Hard - Run Fast - Hit to Kill!!!
  • 07-26-2011 10:34 AM In reply to
    Large48:
    Why??
    You can hang whichever way you like. Just change the L - R switch on the back.
    Regards Graham
  • 07-26-2011 10:52 AM In reply to
    Isn't there meant to be a better 'spread' of the sound due to the speakers being further away from the side walls, so less 'bounce' back?
    all non-teckie speak there! LOL
  • 07-26-2011 11:12 AM In reply to
    Daniel:
    I can assure you the food is great too! Yes -  thumbs up
  • 07-26-2011 11:13 AM In reply to
    Who told you that !!!!!
    If B&O thought that, they would not have put the  switches on the back?
    The installation instructions say that you can mount them whichever way suits your fancy!
    Regards Graham
  • 07-26-2011 7:12 PM In reply to
    joeyboygolf:
    Exactly, I hung them this way (after testing both ways) because it looked more balanced with the painting.
    -Andreas
  • 07-26-2011 7:25 PM In reply to
    joeyboygolf:
    Why??
    Switch the amp units as well and voila, a complete mixed Beolab 5000Big Smile like a real Mondriaan
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 07-27-2011 3:47 AM In reply to
    Leslie:
    joeyboygolf:
    Why??
    That's going too far! Big Smile
    -Andreas
