Latest post 08-04-2011 7:08 AM by shaywhelan. 6 replies.
Page 1 of 1 (7 items)
  • 07-22-2011 5:31 AM
    BeoVision 6 - 26 Record Lock
    I am new to this forum.
    I have a BeoVision 6 - 26 which is locked on one channel and will not allow me to change.  When I try to change channel, "Record" appears on the screen.
    It appears that I have inadvertently locked the TV in "Record" mode with the Beo4 Remote.
    I can't find anything in the BeoVision 6 or Beo4 manuals about this issue - it is mentioned in the BeoVision 5 manual!
    I presume there is a simple method to unlock "Record" mode.
    Can anybody help me?
    Thanks in advance.
  • 07-22-2011 6:36 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: BeoVision 6 - 26 Record Lock
    Welcome to Beoworld.
    Try pressing RECORD - STOP - STOP on your Beo4 remote. This should "stop" the recording.
    Or try to add the buttons "LOCK" and "UNLOCK" to your Beo4 - only available in certain versions...
    Hope this helps.
    Stefan
  • 07-22-2011 6:59 AM In reply to
    Thanks for your help.
    I will try this tonight.
    Shay
  • 07-25-2011 5:39 AM In reply to
    I tried pressing RECORD - STOP - STOP on my Beo4 remote but the TV still thinks it is recording!
    I also tried to add "LOCK" and "UNLOCK" to my Beo4 but these irems did not apear to be available on my BEO4 remote.
    Any other ideas?
    Shay
  • 07-25-2011 7:03 AM In reply to
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    I'm sure you have, but have you tried the customary advice in all these kinds of situation - a re-boot?
    Unplug from the mains, wait 5 minutes or so, then plug in and switch on. I can't see that after power off it still locks into record.
    Having said that though, my Sky+ box does!
  • 07-25-2011 8:21 AM In reply to
    • stefan
    • Posts 1,733
    shaywhelan:
    Any other ideas?
    Shay
    Ok, strange. Did you try a reset? Is it possible to set the BV to standby ? (red stdby light).
    What is connected to your BVs AV1 port? If anything is connected to AV1 with a scart plug, disconnect the plug and try again.
    If this works connect your external device to AV2 port.
    And try to press RECORD - STOP - STOP in V.MEM (V.TAPE) mode. Beo4 RECORD button usually responds just to V.MEM (V.TAPE).
    Stefan
  • 08-04-2011 7:08 AM In reply to
    Apologies for the delay in responding - I have been on holiday.
    I tried the 'old-fashioned' re-boot and it worked.
    Thanks for all of the help and suggestions.
    Shay
