Latest post 07-20-2011 3:45 PM by Vienna. 2 replies.
Page 1 of 1 (3 items)
  • 07-20-2011 2:16 PM
    beotime alarm problem
    when i select radio as alarmsource i simultaniously hear the built in "chime" when the alarmtime is reached.
    can i switch off the chime and just hear the radio????
    thank you.
  • 07-20-2011 3:38 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: beotime alarm problem
    don't think so mine does the same however not tried another source as yet!!
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-20-2011 3:45 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    "When the selected alarm source switches on, you will also hear the sound of an
    ordinary built-in alarm to make sure you wake up."
    Big Smile i'ts not a bug, it's a feature ...
    Filed under:
