Check that he belt pulley on the motor is properly fastened, if not fasten it with Blue Lock Tite or with a little crazy glue, the right way is lock tite. Check your platter bearing is free from damage and wear and oiled, check the platter shaft is 100 % straight and without wear.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
