Latest post 07-19-2011 4:38 PM by elephant. 3 replies.
Page 1 of 1 (4 items)
  • 07-16-2011 5:48 PM
    • cjfc
    • Not Ranked
    • Joined on 09-22-2007
    • Posts 45
    BV 7-32 apple tv HDCP issue
    Hello all,
    I am having a few issues with the apple tv2 I bought today.
    I have ATV connected to a BV 7-32 mk3 (type 9334) which is HD ready.
    Having read many posts on here I have the basics set up and working (connected via an hdmi to dvi cable and the audio via an optical to analogue converter - on PC on AV4). So I am able to see video and music via the linked itunes account / macbook.
    However, I have an HDCP issue when trying to watch a rented film. The error message of ‘This content requires HDCP for playback. HDCP isn't supported by your HDMI connection' comes up.
    Could this be I have an incompatible cable and / or my BV 7-32 does not support HDCP? Is there anything I can do to check on the tv?
    A separate issue issue is that when I had a photo slideshow showing the screen went blank after ten minutes or so but I could still hear the music playing. I pressed menu on the beo4 and no TV menu displayed - but ‘PC' still showed on the red side display. Could this be a screen sleep issue?
    All help is greatly appreciated
    Thank you
    Christian
  • 07-17-2011 1:35 AM In reply to
    Re: BV 7-32 apple tv HDCP issue
    Hi Christian
    Let me see if I can kick this along for you ...
    cjfc:
    Any reason you are not using the HDMI for audio ? That is what I did.
    cjfc:
    It seems possible - I bought a Belkin from the Apple store just to be safe.
    cjfc:
    How did you start the slide show ?
    Did you set it up in the configuration menus on the right hand side of the ATV2 menus ?
    Mine goes for ages as a nice background to music.
    The black screen I get when I come back to the ATV2 after having been watching TV or whatever ... I find I have to wiggle the Beo4 [<<] and [>>] keys to get the screen to wake up ... but I then loose the slide show for a little while.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 07-19-2011 11:34 AM In reply to
    • cjfc
    • Not Ranked
    • Posts 45
    Thank you very much for the reply.
    I have bought a new hdmi to dvi capable and that is working with hdcp so that the rented films can now be watched.
    Re the slide show, I did start it from the configuration menu. I will try again later today to see if the same issue happens on the same slide show so that I can see if it was a one off bug.
    Regarding the audio piece, I must admit I don't know what ADMI is? I have the APT digital optical output into a DAC and then out with RCA cable.
    Many thanks again for your help
    Christian
  • 07-19-2011 4:38 PM In reply to
    Great ! Happy to help.
    cjfc:
    My apologies - my mistake - that was a typo :-(
    Any reason you are not using the ADMI for audio ? That is what I did.
    should be
