Latest post 01-28-2012 6:33 PM by Søren Mexico. 55 replies.
Page 3 of 3 (56 items) < Previous 1 2 3
  • 01-22-2012 6:05 PM In reply to
    Re: Beomaster 2400 DOWN after 6 month
    Søren Mexico:
    Tested the remote I got from Leslie, funny the left side buttons all work, the right side not, will open and investigate, surely some oxidation.
    I had one with some non funtioning keys and another thaat would only work when it wanted to. So i cleaned and recapped both and did some sold resoldering in the battery compartment. both work flawlessly now.
  • 01-22-2012 7:22 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Glad to hear it :)
    Olly.
  • 01-22-2012 8:38 PM In reply to
    Eugene:
    Søren Mexico:
    Thank you Richard, will do the same, but next week plenty of work, and I want to be absolutely sure  the 2400 is working properly before assambling, 3rd time openAngry
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-23-2012 7:22 PM In reply to
    Up and running with speakers now, 1 hour nothing gets hot no channal jumps, will leave her a couple of hours more
  • 01-23-2012 7:27 PM In reply to
    Went checking, but the fuse blew, thats OK, I put a 1 A. in it, should be 2 A, but I didn't have any, tomorrow another day
  • 01-28-2012 6:33 PM In reply to
    Got the fuse, and while cleaning GRAFITI of my white house front and painting, I left the 2400 playing, now 3 hours, nothing hot, no channel jumps.
