Latest post 07-16-2011 12:32 PM by Hardwriter. 20 replies.
Page 1 of 1 (21 items)
  • 07-14-2011 2:52 AM
    iPad and Beoworld Forum
    Took delivery of a 3G iPad this week. Although it's 3G we haven't bothered with a SIM and just use it wirelessly at the moment on our home network.
    It is a great device to use, feels nice, is very intuitive, scrolling and changing between web pages somehow feels far superior to a laptop. It also displays a lot of reading material in a better way than the Kindle, although the Kindle is nicer to read pages on in bright sunlight (assuming what you are reading is formatted for the Kindle because its navigation of anything else is terrible.)
    Anyway, last night I tried the iPad on the Wednesday forum here on Beoworld. What a disaster. Keyboard wouldn't come up onto the display and the iPad eventually had to be shut down completely to get it out of a persistent flashing on and off if a 'Compose' window was called-up.
    Searching the web the iPad seems to have problems with certain forums............. is this because of the way a forum is set up...... is it because the iPad doesn't display, say Adobe Flash, or some  other reason?
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 07-14-2011 3:46 AM In reply to
    Re: iPad and Beoworld Forum
    Hi vikinger,
    Same issue here iPad will not show the keybord for whatever reason. But there is an App out there called Beoworld which works fine on my iPhone.
    As far as I understood there might come some updates along for the forum.
    Beo Time, A8, EarSet3i, EarSet2, BC2, BC6, BL3, BL11, Apple TV1, BEO Ballpen, BL2000, BL3500
    Christmas 2010 Prize Draw 1st winner. BeoSound 9000 Mk3
    Thank you
  • 07-14-2011 4:38 AM In reply to
    Download this App I built for Beoworld:
    http://itunes.apple.com/us/app/beoworld/id398379170?mt=8
    Works on iPad and iPhone.
  • 07-14-2011 4:50 AM In reply to
    vikinger:
    http://forum.beoworld.org/forums/p/39224/325772.aspx#325772
    It is indeed far from a Beoworld specific problem. Apple should fix this, but I'm not expecting them to listen...
    -mika
  • 07-14-2011 5:31 AM In reply to
    PhilLondon:
    Thanks Phil. Downloaded it ...... it gives me Beoworld in a completely different format but I can't see any of the reply etc options. When I go back to the normal browser (Safari) and view Beoworld through that it's just the same: you can call up a reply window but there's no keyboard.
    Have a missed something with using your App?
    Graham
  • 07-14-2011 6:22 AM In reply to
    You need to enter your account name and password.
    This is on the first screen of the App. Tap the Account button.
    Once you've entered your credentials, the Reply button will be active. it is the same button as in the Mail app.
    p.
  • 07-14-2011 6:41 AM In reply to
    Success! At least I think I can reply via the iPad!
  • 07-14-2011 6:48 AM In reply to
    I use every day the Beoworld App. It Works geat. It is easier to read and write than on a PC.
  • 07-14-2011 7:02 AM In reply to
    Great App Phil!
    Works really well. The only problem I now have is that for some reason the Apps icon doesn't appear on the main screen and I have to search for it. No doubt this is just me not being familiar with the peculiarities of the iPad.
    Graham
  • 07-14-2011 7:06 AM In reply to
    vikinger:
    just drag the Beoworld App's icon from where you find it, down to the task bar thingy, and let go
    now it will be at the bottom of every screen for instant access !
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 07-14-2011 7:10 AM In reply to
    There are several "main" screens. Swipe from right to left to go from one to another.
  • 07-14-2011 7:37 AM In reply to
    PhilLondon:
    Thanks Phil & Elephant!
    Sorted.
    You always feel such an idiot when these things are so obvious after the event!
    Graham
  • 07-14-2011 7:56 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    vikinger:
    PhilLondon:
    Sorted.
    Graham
    WhistleLaughingLaughing
  • 07-14-2011 10:24 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    You must enter "HTML mode" in the reply window in Safari. In the message bar, close to the smiley icon you find "HTML", press that to enter a new window with keyboard. You need to tap the typing area to be able to start writing. When you finished writing press "UPDATE" at bottom left to get back to reply window where you click "POST".
  • 07-14-2011 6:13 PM In reply to
    Just trying Daniels HTML approach in Safari. Works OK but Phils App is easier! Graham
  • 07-14-2011 6:54 PM In reply to
    Great app
  • 07-14-2011 6:56 PM In reply to
    vikinger:
    Jack Daniel's I assume?
    Laughing
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 07-15-2011 3:23 AM In reply to
    bayerische:
    vikinger:
    Laughing
    That might improve things!
    Something I realised last night with another post: using Phil's App I couldn't find the Edit option to correct a typo after I had posted an item. Does the App have a hidden Edit function? Also couldn't see a way of quoting from a previous post.
    Graham
  • 07-15-2011 6:07 AM In reply to
    vikinger:
    It doesn't, no.
  • 07-15-2011 7:41 AM In reply to
    PhilLondon:
    vikinger:
    It doesn't, no.
    Thanks Phil. Saves me searching for what isn't there. Guess you just have to be careful what you post or try editing later from another Mac/PC!
    The App is a great interface nevertheless!
    Graham
  • 07-16-2011 12:32 PM In reply to
    Getting back to the original post, this is a problem not just with the ipad but will all tablets. They all - apple, Android, etc, seem to have problems translating some traditional PC platforms. I was hoping the BB Playbook was going to change things with its flash support but having tried it it seems rather clunky as well.
    Apple are not likely to come up with solutions to most of these issues as they want to drive all of their users through their Appstore channel. I have quite a few Apple products - Ipods and computers - but I must admit the company's efforts to lock everyone in to the Apple environment does grate a bit at times.
