Latest post 07-10-2011 2:27 PM by SWISS_2. 2 replies.
Page 1 of 1 (3 items)
  • 07-10-2011 4:19 AM
    No sound from left channel
    i recently took down one of my beolab 4000 speakers from the wall to decorate, i have put it back and now have no sound. The right channel is fine (i didnt move this) but the left speaker which has 2 power link cables going in isnt (i assume 1 of these is a link to the other speaker). I did get some feedback when i move them would this have blown anything??
    i tried the speaker downstairs in my lounge to check out if it was this, it didn't work and now neither does the speaker that i un-plugged to test it. I have now stopped touching things as i clearly don't know what im doing!!
    Any help is appreciated, before i get an engineer out.
    matt
  • 07-10-2011 5:01 AM In reply to
    Re: No sound from left channel
    Hi Matt,
    Welcome to BeoWorld! I can think of two problems with your BeoLab 4000. Is the red Stand-By indicator on the front on? This is also a mains switch. Just push the light indicator. Another problem could be the switch on the back of the BeoLab 4000. It say L/R/LINE. It has to be set to L or R, depending on if your BeoLab 4000 is placed on the Left or the Right. Maybe the setting is changed when you took of the speaker.
  • 07-10-2011 2:27 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Agree with Blacktrix;
    1. The front standby buttons on the lower front of each speaker can accidentally be turned off when handling the speaker. It has happened to us a few times when moving the speaker or changing the colour plates.
    2. If the L-R speaker switch is selected (L or R) and you still do not have power or sound, then it is either a defective active power cord, or the speaker fuse that might need to be replaced.
