Hello all,
Earlier today I purchased a Masterlink Gateway to work with my B&O products. No manual followed, I've plugged the different cables in, connected by an ethernet cable. Lights up green - seems to be ok. But when I try to access my router configuration page to see if the Masterlink Gateway has obtained an IP-address, there is none. I have tried to reset the settings on the mlgw by the setup button, nothing seems to work. The IP-address won't be obtained. I've also connected the mlgw directly to a computer and used the cmd to find out what the MAC-address is. I've then plugged it back in on the router and made an IP-scan on the network and compared the MAC-addresses from the IP-addresses in use with the one MAC-address I've have for my mlgw. None. It's not there. So to be exact: My Masterlink Gateway does not obtain an IP-address on the router (which is Zyxel).
Any help on this matter would be greatly appreciated.
Thanks in advance,
aSkovk
