1st March February 2012
Latest post 07-19-2011 1:32 PM by Iconic-AV. 13 replies.
07-09-2011 9:04 AM
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Re: These look great! (good advert too!)
Llewelyn: Any thoughts on tweed? I like!
Me too, and the tweed will keep them warm
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Rich
- Joined on 07-11-2010
- Orlando, Florida, USA
- Posts 1,089
A little bland compared to what I'm now used to...
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Lots of talk, what about the "Bang & Olufsen" print what you can see through the cloth?
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Eugene
- Joined on 12-17-2008
- Posts 589
Leslie:
I dont believe the RL35 had the embossed Bang & Olufsen on the front panel. rather it was just an ordinary piece of partivle board.
Søren Mexico
- Mexico city
- Posts 1,621
Eugene:
Leslie:
They look good and as there are no other speakers like these ever made, we dont need the "print", and I think He/she Eugene is right.
Forthermore I think the guy made them for Scotland. Look who is talking
Leslie
- Netherlands
- Posts 2,201
Eugene:
Oh? Thought that all RL's have the embossed printing on the front panel. If that's the case then indeed it looks great. It's not that easy to have the embossed printing when re-clothing those panels, in fact impossible with such a thick tweed this person has been using. Eugene, you fascinates me with your avatars masked face. Very mysterious
Leslie
- Netherlands
- Posts 2,201
Oh no Søren! You started using masks for your Avatar as well
kennerd
- Joined on 04-21-2011
- Posts 48
Eugene:
Leslie:
I have 4 RL35's and yes, they are embossed. I
ronically, though, they do not have the keyholes ont he back for wall mounting. They had a metal leg that allowed them to lean back at an angle either veritcally or horizontally only. Given that they were the smallest of the RL's, it's a real shame, since I just moved that system into a small office, and wall mounting would be ideal. Beforehand, then were tucked in the corners of a larger room.
Søren Mexico
- Mexico city
- Posts 1,621
You could get one of these made, the pic is for a RL 140, bigger than the RL 35s, a lot of holes, but you only need 2 holes to fit to the wall, and with the adjustment screw you can adjust the incline
Leslie
- Netherlands
- Posts 2,201
kennerd: I have 4 RL35's and yes, they are embossed.
No embossed printing? Then it's like RL35's with sweaters...
kennerd
- Posts 48
Søren Mexico:
First off: Apologies for the poor lighting!
Interesting, but mine have only 3 holes on the back, and there is not enough inset inside the hole (hard to describe), or lip inside the hole, to use efficiently (or safely) to hang the speaker....I'd be interested on the method to attach these...
My set up looks striking similar to the auctioneer right now (just moved the office into this room, and have yet to hang the BM 3300 on the wall..
And for the curious: the embossing
Søren Mexico
- Mexico city
- Posts 1,621
Take a look here , no original brackets. Only way as I see it is to open the speaker and look for a suitable place, to from the inside, fix a selfmade bracket to the outside. Its a little complicated, but doable.
If you deside to do it post pics.
Page 1 of 1 (14 items)
