Latest post 07-29-2011 4:16 PM by Ferdinand. 4 replies.
Page 1 of 1 (5 items)
  • 07-06-2011 4:34 PM
    BS9000 stand, how to secure (attach) BS9000 to floorstand?
    Bought a BS9000 floorstand on auction site Lauritz.com
    How do I secure the BS9000 to the stand? Does this work with standard screws that came with the BS9000?
    I have both a wall-plate (horizontal) as a table stand, but something is telling me that I need different (bigger?) screws? See picture attached
    What I have now are black screws with plastic support 'thingies'
    BS9000, Beolab 3000, Beocenter 7002, RL60.2, beo4, BV10
    Filed under: ,
  • 07-06-2011 5:47 PM In reply to
    Re: BS9000 stand, how to secure (attach) BS9000 to floorstand?
    If you download the BS9000 Mk3 service manual from this site you will be able to view the diagram of the stand and fittings with part numbers.
    Regards Graham
  • 07-07-2011 11:56 AM In reply to
    Done and thanks Graham. I did not expect to find what i need in that manual.
    According to page 66 I need parts 6 and 7, screw and bushing, I'll order them at B&O
  • 07-14-2011 7:25 AM In reply to
    Yes they are big t-shaped thingies with a whole through them for Alan keys.
  • 07-29-2011 4:16 PM In reply to
    Parts have arrived within two days Yes -  thumbs up to be picked up at my B&O dealer which I off course did.
    It was ordered at B&O in Denmark and -for me- to no costs (they actually costed 250SEK = 28 Euro)
    BS9000 is now on it's new stand (and yes I remembered to change the CD mechanism settings).
    For all of you bying such as stand 2nd hand (like me) via an auction site (like me) , check if screws are there, that makes everything a lot easier.
