Latest post 07-07-2011 3:30 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 07-06-2011 1:28 PM
    • jahur
    • Top 500 Contributor
    • Joined on 02-07-2011
    • planet zonk
    • Posts 161
    MMC4 failure, or is it?
    hi all,
    been a while, may have a stylus failure, played a couple of albums today all was fine, then the third, it started to sound like there was a lot of dust collecting on the stylus, there was, cleaned it, replayed the album and it started again, no dust this time. so i tried a brand new vinyl album and it still was producing the sound as if dust was on the tip. it cleared a little then went back to sounding as if it was dusted up, for which it wasnt.
    are these the characteristics of a failed needle? anyone help? its on a beogram 9000
    (formerly nokinnikon from the old site)
  • 07-07-2011 3:30 AM In reply to
    Re: MMC4 failure, or is it?
    Yes, distorted sound is a symptom of a worn stylus.
    Unfortunately, there is no effective way of checking other than replacement with another or get yours re-tipped by Axel.
    Regards Graham
