Latest post 07-06-2011 9:24 AM by elephant. 6 replies.
Page 1 of 1 (7 items)
  • 07-05-2011 1:54 PM
    Connecting a non b and o tv to beosound 2300 via aux and beo lead with 2 phono sockets on one end !
    I have recently connected my non b and o tv to my beosound 2300 hifi via b and o lead plugged into the aux socket !I am having a problem as I want to be able to operate the sound from my beo 4 remote but I cannot do it it means I have to manually go to my hifi and select aux then operate sound,but if I then press radio or whatever on my remote I cannot get back the aux on my hifi and need to go to hifi and manually press aux again !!
    Any Ideas ??
  • 07-05-2011 4:40 PM In reply to
    Re: Connecting a non b and o tv to beosound 2300 via aux and beo lead with 2 phono sockets on one end !
    Try SHIFT - RADIO,via the Beo4?
    Nick
  • 07-05-2011 5:29 PM In reply to
    Best to just add A-AUX to the list on the Beo4
    Regards Graham
  • 07-05-2011 7:09 PM In reply to
    i AM NEW TO B AND O HOW DO i ADD ON MY REMOTE,i AM A COMPLETE NOVICE!
  • 07-05-2011 7:55 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    You need to add "A.AUX" as a virtual button to your "LIST" (as described in the Beo4 manual).
    - Press "STANDBY" (red dot button) and "LIST" simultaneously.
      (Beo4 display should display "ADD?" - if not - repeatedly press "LIST" till display is showing "ADD?")
    - Press "GO"
    - Press "LIST" repeatedly until "A.AUX" is displayed.
    - Press "GO" - the Beo 4 should display "ADDED"
    To select a function/source of your "LIST"
    - Repeatedly press "LIST" until the desired function/source is displayed
    - Press "GO" to send the command.
  • 07-05-2011 8:51 PM In reply to
    Sorted it works now cheers Guys !!I didnt know remote could do so much!!
  • 07-06-2011 9:24 AM In reply to
    JONNIE:
    Pay the dues, join the club, download a Beo4 manual, and discover the power of what you have in your hands !
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
