Latest post 07-29-2011 4:56 PM by Blackrix. 8 replies.
Page 1 of 1 (9 items)
  • 07-03-2011 5:49 AM
    Beolink 7000 battery
    what is the battery of BeoLink 7000? Is it hard to find?
  • 07-03-2011 12:41 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beolink 7000 battery
    You need a 5 cell, 6 volt Ni Cad battery pack (Ni MH batteries will work for a while but not for long apparently).
    I'm not sure if B&O can still supply these, but they will be expensive even if they do. I would suggest obtaining a battery pack from another source (eg a model shop) & swapping the plug connector.
    Chris.
  • 07-03-2011 2:33 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    I replaced the battery pack with new cells. I soldered them together (like the original) and used the power cable from the original pack. The originals were Sanyo Cadnica 1.2v 700mAh, new ones were (by surprise) also Sanyo Cadnica, this time 1100 mAh. Even higher capacity ones were available but out of stock at the time I bought them.
    Has been working perfectly. The battery compartment is a bit tight so no much space for alterations.
    Left: original battery pack, right: my self-made new version.
    Bang & Olufsen - The art of controlling sound, picture and light
  • 07-27-2011 3:32 AM In reply to
    • psand
    • Not Ranked
    • Joined on 05-05-2010
    • Stockholm, Sweden
    • Posts 48
    • Gold Member
    I replaced my BL7000 battery with a newly made kit which I acquired from Thorsten Janz in Germany (eBay handle: netsroht66). It works like a charm. As I just discovered that he offers this item again, I'll post a direct link to eBay auction 270789375653 . Worldwide shipping and the price is fixed at EUR 24.90.
  • 07-27-2011 4:11 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I would be surprised if NiMh were not suitable Chris...
    Olly.
  • 07-27-2011 4:59 AM In reply to
    Step1:
    Apparently not Olly, something to do with the charge/discharge rate.
    Could be fact, could be bull sh1t, certainly it has come from a number of sources over the years.
    Regards Graham
  • 07-27-2011 2:56 PM In reply to
    • Medogsfat
    • Posts 4,045
    That's what I heard Olly.
    As Graham has mentioned above this will cause them to work for a limited period of time until the charges last less & less before falling off the edge. Again I am only stating what I've heard a few times so it isn't from 1st hand experience. I have no reason to dispute it & I cannot think anyone would simply make it up.
    Chris.
  • 07-27-2011 3:16 PM In reply to
    It's probably the charging method. If a dumb charger is dimensioned so that it won't cook NiCd batteries no matter how long you charge them, it'll never get NiMH batteries full.
    -mika
  • 07-29-2011 4:56 PM In reply to
    I have Ni-MH batteries in my BeoLink 7000, without any problems yet. But the ones I have installed are 700 mAh, just a bit higher capacity than the original. I ordered them at Conrad, ordernumber 255670.
