Anyone have any idea how to use the SP/DIF input on a Beosystem 2? The manual says just plug it into SP/DIF 1, but it also insists on having the SCART feed the audio as well (at least in the manuals it does unless the source is VGA). In fact removing the SCART cuts the audio completely, suggesting to me that the SP/DIF connection just isn't used.
I'm keen to use this so I can remove the SCART completely from the system!
