Latest post 06-28-2011 10:25 PM by Lindystar. 2 replies.
Page 1 of 1 (3 items)
  • 06-26-2011 4:18 PM
    • Lindystar
    • Not Ranked
    • Joined on 04-16-2011
    • Des Moines,Iowa
    • Posts 4
    Beogram 1700 speed issues
    I'm new to the B&O world and loving every minute of it! The problem I'm having with my near mint Beogram 1700 is once in awhile when I push the 33 rpm button, it plays in the 45 mode. If I push pause, then 33 again, it usually plays in the 33 mode. Any ideas on what could be wrong?
    Thanks,
    Eric
  • 06-27-2011 5:36 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1700 speed issues
    Eric,
    Welcome to Beoworld !
    I'm almost sure that the "alternative" speed is exactly the double of the normal, that is 66rpm instead of 33.
    This is almost always caused by a slipping belt.
    The motor will spin up too easily, it will reach a too high speed and
    the electronics will happily lock it there.
    There can be other reasons but a worn belt is by fra the most often seen.
    We had other threads regarding this issue on similar decks but the
    essence of it is the above.
  • 06-28-2011 10:25 PM In reply to
    • Lindystar
    • Not Ranked
    • Des Moines,Iowa
    • Posts 4
    Thanks for the reply Martin, I will check the belt and get it replaced.
    cheers
    Eric
