THANK YOU ALL !
Just putting the front panel on the tuner/amp together now. I have cleaned the relay contacts with 1200 grit wet and dry and put on some switch cleaner so hopefully it'll be ok.
The tape deck plays briefly and then stops so it seemed to me from a standpoint of ignorance that that there may be a micro switch that is meant to be activated to confirm the deck is in "play" which isn't being activated for some reason. Will look at the belts of course when the amp's back in one piece.
The deck too will be apart in due course.
If I may ask a general question ? I know nothing about B&O stuff. I've had old English valve hifi in the past ( Leak QUAD ) and am now using an old Marantz tuner amp. Very flashy and totally unlike the B&O !
Anyway, my question is in hifi terms, is the Beosystem 5000 highly rated ? The look is fantastic and I love the (huge) remote but is their beauty more than skin deep ? This in not meant to be provocative it's just that I am completely new to this equipment.
I also have a pair of CX100 speakers with blown surrounds which I am going to repair. Are these good too ?
Yours,
Jolly
