1st March February 2012
Latest post 12-07-2011 3:18 PM by chrisped. 33 replies.
06-25-2011 2:14 PM
frog
- Joined on 04-19-2007
- Posts 191
Ah, that would be the Panasonic TH-85VX200! http://panasonic.net/proplasma/products/85vx200/index.html
Only $30,000 - much better price..... same thing.
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
I know it may look like I'm going back on what I've previously said... but is this really the exact same thing?
Massive price difference, granted - but the 85" being BeoSystem 3 based, it's surely better than the 'off the shelf' Panny?
I've seen the BV4-85 3D in action, albeit for about 5 minutes, at the factory in Struer - and was truly impressed.
Lee
9 LEE
- Moderator - UK
- Posts 5,223
Paul Winn:
65K for a TV? That's vulgar!!!
I'm with you a little, but so would a £50 meal for two be at a restaurant if you earned £10 a week in a third world country. It's all relative to what you earn I suppose..
Stripping it down into actual cost of components, it's ludicrous - but when you've got the overheads of Bang & Olufsen you've got to make big margins.. Also, if you want 'cutting edge' you'll always have to pay top dollar.
Lee
symmes
- Joined on 04-21-2007
- Freedonia
- Posts 290
9 LEE:
Lee
If that's so, all you have to do is buy the frame, aka its designer clothes.
9 LEE
- Moderator - UK
- Posts 5,223
symmes:
... and we're off !!!
Nickyg63
- Joined on 08-28-2007
- Nottingham
- Posts 628
9 LEE:
symmes:
light the touch paper and run!
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Does the BS3 cost extra?
I'd genuinely love to know how much time and effort B&O have invested in tweaking the internals of the Panny panel.
frog
- Posts 191
It isn't Beosystem 3 based - it is just the display. Connect a Beosystem 3 to either and you have a working solution.
Panasonic VX200U = Bang & Olufsen Beovision 4-85 (without the nice frame).
Do you really think B&O have the resources to change the 3D processing in the panel?
BeoMegaMan
- Joined on 11-25-2007
- Posts 66
not from what I understand and have seen. The BV4 has a seperate IR panel integrated into the bottom of the frame which is a new proprietary IR sync system (B&O purchased) to run the sync of the glasses. Plus naturally 3D can only be transferred via a HDMI signal which has also been switched out from the old DVI only outputs of the old BS3. If you can find a new BS3 only and a way to setup a modular IR sync then you would have a simple solution as explained...... it's not like the old 42/50/65's :)
BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
Alex
- Joined on 04-16-2007
- New York, NY
- Posts 176
frog:
Clearly you havent seen it.
Store Manager
Bang & Olufsen Broadway
927 Broadway
New York, NY 10010
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
Alex:
frog:
Is it really twice the price better?
Have you seen them side-by-side???
My B&O: 2009 Catalogue and Pricelist
BillC
- Joined on 04-25-2007
- Posts 16
Like many luxury goods, the value proposition of the BV4-85 is highly subjective.
Personally given the pace in visual display technology, the relative pricing of the BV4-85 seems excessive to me.
Then again, I think the pricing of the Beolab 5 is quite reasonable - many would think otherwise....
BTW I'm curious if anyone could explain the vast difference in the power consumption figures quoted for BV4-85 on the B&O vs that for the VX200 on the Panasonic website. Is the BV4-85 far more power efficient or is it just a matter of difference in the way power consumption is measured by the companies (apologies for my ignorance)
B&O BV4-85
POWER CONSUMPTION |
Typical (IEC 62087:2. ed): 375 W/Networked standby 0.4 W |
Panasonic
Model |
TH-85VX200U |
TH-85VX200W |
Power Consumption |
1,250 W |
1,200 W |
On Average Power Consumption* |
739 W |
Power off Condition |
0.2 W |
0.3 W |
Stand-by Condition |
0.3 W |
0.5 W |
frog
- Posts 191
BeoMegaMan:
Now this IS interesting if it is the case - and also puzzling why they would do this. The synch of the glasses is a pretty mundane thing - needing only 60hz per eye for the shutters (assuming 120hz framepacking mode, which Panasonic use) - and really no need for a 'specialist' solution. I wonder why they did this - the press release makes no mention of it - concentrating on the motorised stand, and I would have thought they would have done if they had introduced something new. My guess is that they have had to add a new emitter because the bezel would be in the way of the Panasonic one!
With regard to your other point, I assume (as I haven't done this yet myself as I don't have a 3D TV) the Beosystem 3 can output a 3D switching signal to an appropriate TV, and, as DVI is electrically compatible with HDMI, with the right plug on the other end (HDMI 1.4 3D connector), then there should be no issues for the system to work well. Again there is no mention of needing a different Beosystem 3 to drive the screen in the press release.
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
BillC:
I can't remember seeing a single person who has argued that BL5s are "overpriced", which means that just about everyone would agreed they are quite reasonably priced.
Indeed, compare the BL5s price point with rival speakers and they come in very competitive. The BV4-85 is less competitive - it's twice the price as its nearest competitor. I don't think that makes the BV4-85 comparable to the BL5s.
vlohjr1
- Joined on 06-26-2007
- Posts 106
At 14.5k the price of a new BL5 is getting a little stretched, certainly when at launch price of 10k is very reasonable.
At Harrods I compared the Panasonic 103 and went to the knightsbridge store to watch the 85 soon after, somehow the 85 is much more vivid and more'alive'.. The 'extras' that B&O has put on is certainly worth the money for a particular set of buyers.
I wonder why there is no 3d for the 50 and 65. The picture quality should be as stunning.... and should bring the price down.
Vince
Puncher
- Posts 9,588
vlohjr1:
Vince
What were the relative settings of the TV's?
BeoMegaMan
- Posts 66
B&O would need to set themselves apart from the crowd as usual, that could be the thought process behind the glasses one would think.
As far as 3D, you will have to have an updated BS3 with HDMI out to take advantage of 3D, period at this point. I don't beleive DVI will carry 3D so that would be the reason why it is only HDMI(v1.4) now.
pure speculation though :)
Alex
- New York, NY
- Posts 176
BillC:
B&O BV4-85
POWER CONSUMPTION |
Panasonic
Model |
TH-85VX200U |
TH-85VX200W |
Power Consumption |
1,250 W |
1,200 W |
739 W |
0.2 W |
0.3 W |
0.3 W |
0.5 W |
From what I understand the power supply is replaced on all BeoVision 4's to something a little more custom that creates less noise than what's normally built in to the Pro series ... Though most would still argue that it's just a Panasonic with a pretty frame
Store Manager
927 Broadway
New York, NY 10010
vlohjr1
- Posts 106
sorry no idea, no techno geek!
i presume factory settings?
went by Harrods again to pick up a 3d blue ray sony (good value with discount and multi region) in preparation for 7-40 3d
screen only non DVD £5300, with 3d blue ray £7700!
Vince
