Let's have a closer look on that weird remote:
and the inside:
Built in 06/1989 according to the stamps on the upper and lower case. Basically it's just a Beolink 1000 with a thin metal foil attached to the front (as on all 80ies B&O gear, double sided tape:), they just cut the keypad to fit.
