Latest post 08-29-2011 10:49 AM by PerroMal. 4 replies.
Page 1 of 1 (5 items)
  • 06-22-2011 3:17 PM
    B& O remotes 1000 and Beo4.
     I have an old B&O set up 9500 which uses the remote 1000.  I have later equipment but I use the 9500 in my study linked to my PCs and TV.  I use "Shift"ATape" for some functions.  When using the Beo4 remote this operation won't work.  I relaise that B&O make a note in the B&O manual that there is not full compatabilty between these controllers.  Does anyone know of a work around.
  • 06-22-2011 5:41 PM In reply to
    • Teddy_fr
    • Not Ranked
    • Joined on 04-16-2007
    • near Angoulême, France
    • Posts 250
    Re: B& O remotes 1000 and Beo4.
     Hi PerroMal !
    It's very easy:
    press the  ||||| |||| button and | LIST| at the same time.
    Then ADD? appears on the Beo4 screen.
    Press | GO | and several times | LIST| until A.TAPE2 appears.
    Then press | GO | to store this new fonction, | GO | again and  |||Tape 2||| switches on on the display of the Beocenter 9500.
    Enjoy your 9500, this machine is really timeless and will work either with the oldest and newest B&O equipments.
    Marc Smile
  • 06-23-2011 7:46 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    Just to add:
    If you have a later Beo4, maybe with A.MEM and V.MEM buttons, and you can`t find A.TAPE2, try N.MUSIC. It`s the same command and works on a BC9500.
    Stefan
  • 08-29-2011 10:47 AM In reply to
    Hi Teddy Fr.
    Sorry this is a very late reply but thank you for the advice.  Works OK
    PerroMal
    UK
  • 08-29-2011 10:49 AM In reply to
    Hi Stefan,
    This worked OK.  Sorry about the late reply.
    Regards
    PerroMal
    UK
