1st March February 2012
Latest post 07-11-2011 3:53 PM by iJoha. 6 replies.
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Re: Beosystem2 with 3rd party Plasma
you need to "short-curtuit" e.g. connect two pins on the rs-232, forget which ones (TX and RX?), search the forum here.
This way the BS2 thinks it got feedback from the Panel.
Did it myself when I used to have a BS2 and connected a VGA monitor for setup...
Best regards
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
kallasr
- Posts 1,077
Check this (BS2 Speaker Setup) and this (Beosystem 2 display output).
Ralf
iJoha
- Joined on 06-21-2011
- Posts 5
Many thanks for the Tip I will try it tomorrow, but one more ? do I still need a sort of signal converter? RGBHV 50khz - RGB60Khz ?
when I was tryng today I got no picture and the Samsung Plasma show (unsuported resolution.... or no Signal)
iJoha
iJoha
- Posts 5
Many thanks for the tips, it worked
Beosystem2 with Samsung SmartTV 55" with the signal converter using Components
and shorting Pin2-3 on the RS232 connection
Many thanks, Happy day
iJoha
kallasr
- Posts 1,077
iJoha, thanks for giving feedback.
What is the manufacturer/model of the signal converter you used?
Ralf
iJoha
- Posts 5
the Signal converter model is CP251F from Lektropacks (http://www.lektropacks.co.uk/view_product_standard.php?product=90&department=239&sub1=99&show=99&department=99)
its realy a good universal scaler and converter, my customer wahtching his Beosystem2 in 720P on 55"
Thanks Again
iJoha
Page 1 of 1 (7 items)
