Latest post 06-20-2011 9:33 AM by classic. 10 replies.
Page 1 of 1 (11 items)
  • 06-19-2011 11:32 AM
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    What is this? - Help please
    I have found a most strange product.
    The label:
    NR 5000 - Type 2012 - Serie 02
    Nr. 74723
    Of course I have the product here, but I will wait to tell what it is (or supposed to be) until I have a couple of input / help please, because for me ....... something is really wrong or at least totally unknown to me.
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
    Filed under:
  • 06-19-2011 12:09 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: What is this? - Help please
    I am not quite sure what is special about this one.
    Beomaster 5000 was available as types 2005, 2012 and 2013
    "NR 5000" is the production name, "2012" is the type number, "serie 02" is the build series
    "74723" is the serialnumber, the stamped "P3" refers to the type of veneer used
    and the "godk" has the approval controllers signature.
    The type 2012 may not be very common in Denmark, is that it ?
    Or maybe it's because the serial number is quite high for a serie 02 ?
    I think, you need to tell us more.
  • 06-19-2011 12:32 PM In reply to
    Could it be a record deck labelled as a Beogram 5000.
    Doesnt make much sense but its my guess.
    If its got you stumped then the rest of us will struggle!
  • 06-19-2011 12:43 PM In reply to
    • Dillen
    • Posts 5,008
    In that case, it would be a record player labelled as a receiver.
    Record players from that period of time has a GR rather than a NR, which was used
    for receivers (and some Beocenters).
    But of course, the label could sit on a wrong machine, I've seen that happen a couple of times before like
    on this Beovox S40 that has a S45-2 label (note that the S45-2 cabinet backside is not composite and does
    not have the hole at the top so the black label that looks a bit skewed is the correct one) :
  • 06-19-2011 1:02 PM In reply to
    That makes sense, maybe someone just stuck the wrong sticker on it by mistake or is it a real mystery item?
  • 06-20-2011 9:08 AM In reply to
    • classic
    • Posts 224
    Thanks for all the suggestion, here is the next pictures....
  • 06-20-2011 9:11 AM In reply to
    • classic
    • Posts 224
    This a version with cer. filters.
  • 06-20-2011 9:12 AM In reply to
    • classic
    • Posts 224
    and with the Görler tuner.
  • 06-20-2011 9:16 AM In reply to
    • classic
    • Posts 224
    This is my registrations of Beomaster 5000 serie / sn.
  • 06-20-2011 9:20 AM In reply to
    • classic
    • Posts 224
    This is my findings re: versions of Beomaster 5000
  • 06-20-2011 9:33 AM In reply to
    • classic
    • Posts 224
    So why is this Beomaster 5000 strange?
    The alu- facia is with only the frequency panel - the channel panel is emty.
    The Ceramic filters: This version have the piggy-back version - this has for me only been seen in serie 5
    Görler tuner: This version is with Görler tuner - this has been know from serie 3
    The serial no: I have never seen any Beomaster with a number near this sn and I have never seen any Beomaster 5000 of serie 2!
    If this type 2012 - serie 2 was for the US, I would expect to see the demphases for US (75uSec) - but the deemphases is for Europe.
    This is truly a strange member of the Beolab 5000 family! Smile
    /Frede
    Filed under:
