I bought a used BeoSound Ouverture and it was presented with the glass doors detached? How do I install the doors? Why do not I hear on the radio no sound with no doors ? Thanks
There are no speakers in the Ouverture. You must add a pair of external Beolab speakers.
The doors are a press fit into the sliding brackets. Suggest you disconnect from mains before fitting doors!
Make sure the doors are fitted according to the orientation instruction on the inside of the glass!
Regards Graham
Ouverture is connected to beolab 4000 and cd sounds. But radio no! is it necessary aerial????
For FM the Rabbit ear antenna, and search for stations.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
But is it necessary? aerial is inside beosound or not?
but is it necessary? no sound from radio, is it mute!
You will definitely need an external aerial. One for FM and another for AM.
There is no aerial inside the Ouverture.
