1st March February 2012
Latest post 06-19-2011 8:31 AM by Blackrix. 17 replies.
06-16-2011 3:33 PM
plumber77
- Joined on 06-16-2011
- Posts 10
I recently bought a 2300 system with beolab 2500 speakers off ebay as a starter.
In the near future I am looking to move house and set up speakers in different rooms and was wondering if it was possible to have multiple speakers connect with the 2500.
I was thinking maybe a beokab 2000 in the bedroom and a pair of 6000's for another room.
Ipod or computer linking is not an issue as I recently bought the Beosound 8.
Kind Regards for any advice...!
Blackrix
- Joined on 04-20-2009
- Posts 975
Welcome to BeoWorld! I think the first advice is: Enjoy your Bang & Olufsen system!
And now for the technical part. You need a T1611 converter to be able to connect a Master Link system to your BeoCenter 2300. After that you can connect up to 15 ML products to your BeoCenter 2300.
A BeoLab 2000 can be connected to the T1611 converter. To connect the BeoLab 6000 speakers in another room you need a T1636 BeoLink Active. But do you also have a B&O television you want to connect to your system?
plumber77
- Posts 10
No TV. I rarely watch TV. Simply I just need music in other rooms.
I don't even need to control the music from other rooms. I would just like to play a CD and listen to in on various speakers around the house.
Hiort
- Joined on 04-17-2007
- Posts 383
plumber77:
It´s not possible to add Beosound 8 into a link system.
/Claes
_____________
Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
1:st prize winner Beoworld January Price Draw.
plumber77
- Posts 10
Understood. I was using the beosound 8 seperate anyway with an Ipod connected.
Surely I must be able to just add a pair of 6000 speakers or similar to my existing beosound 2300.
Run 2 extra speakers as well as the beolab 2500's. I just want a simple system without the need for control all over the house. just play a cd on my system and it come out of extra speakers??
stefan
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
plumber77:
Yes, yoa can add BL6000s by using a Powerlink Y-splitter. The speakers will also get on-off commands via Powerlink. So, all speakers will be on or off.
BTW: "Beo`s "All over the house control" is simple.
Stefan
plumber77
- Posts 10
How do you mean simple??
I understand the beolab 2000's has control by selecting tape/radio/cd etc but is this possible with powerlink as my unit is older or would I need to get adaptors to masterlink?
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Run power link cables from speaker to speaker, each BL 2500 has 2 power link connections, BL 6000 as well, the 2300 also, so from 2300, 1 power link to BL 2500 R or L and from R to L, 1 powerlink from 2300 to BL 6000 R or L and from R to L or visa versa, on the last connected BL you will have an empty powerlink connection that one you can connect to more BL speakers.
One powerlink cable runs trigger power and lines for both R/L speakers, if the BL has 2 PL connections you can use one cable from 2300 to R BL from R to L BL, just remember to set the BLs selector to L or R
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Mexico
- Mexico city
- Posts 1,621
I forgot, as the BS 8 has no line out, get a cable that connect Ipod to AUX in, in the 2300, that way you can play your Ipod as well
stefan
- Posts 1,733
plumber77:
I mean simple to install and simple to use. You just need one Beolink converter (1611) for your Beosound and you can connect BL2000, BL3500, Beolink active, passive, all newer Beovisions in linkrooms with Beo4/6 control from every linkstation and independant volume control via one single Masterlink cable. This is not possible if you just add speakers - but it will work too.
Stefan
plumber77
- Posts 10
thanks for your help.
how do I find out which powerlink mark I have on the unit, ie mark i, ii or iii
Søren Mexico
- Mexico city
- Posts 1,621
1) Powerlink mark 1 cable is only useful for non-digital Beolab speakers without displays.
2) Powerlink mark 2 can be used for ANY Beolab speaker with 8pin sockets.
3) Powerlink mark 3 can be used for any Beolab speaker WITHOUT displays EXCEPT Beolab 5.
plumber77
- Posts 10
stefan: I mean simple to install and simple to use. You just need one Beolink converter (1611) for your Beosound and you can connect BL2000, BL3500, Beolink active, passive, all newer Beovisions in linkrooms with Beo4/6 control from every linkstation and independant volume control via one single Masterlink cable. This is not possible if you just add speakers - but it will work too.
Is it possible to have the beosound 2300 with beolab speakers on one rooms with a pair of 6000's connected directly to them then using a beolink converter add a BL 2000 in say a bedroom so it has independant control.
I have looked around and can get the converter for about £60. (I think!)
plumber77
- Posts 10
Thanks.
So I just need a beolink converter? 1611 I was told
I presume I could daisy chain the 6000's with the beolab 2500's which are already on the BC2300.
stefan
- Posts 1,733
For your setup with BL2000 you need a BL converter - 1611 - an AUDIO AUX LINK cable (7pin DIN plugs), a Masterlink cable and ofcourse a BL2000.
Yes, you can daisychain BL2500 and BL6000 via Powerlink connected to your BC2300. You won`t have independant control between these two speakers. But you will have independant control between this (main) setup and BL2000 (link) setup.
You can find interesting info about Beo-setups on the Beotech site. Masterlink setups with BL converter and BL2000: http://www.beoworld.org/beotech/options3.htm
Hope this helps.
Stefan
plumber77
- Posts 10
thanks alot. That is very helpful indeed
Page 1 of 1 (18 items)
