Hi, i have some problem on this beogram need you guy's help.
2 of the cable broken in the red circle part, and i not sure whether i connect it correctly. the green and black wire broken.So i just connected it by guess work.
Anyone have similar TT? can you take a photo on this part
The problem now is that when press "Start“button, the motor will run, but it will stop immediately after the hand release from the start button.
Any advice?
Thanks.
[View:http://forum.beoworld.org/themes/beotheme1/utility/
