1st March February 2012
Latest post 06-15-2011 3:32 AM by Flappo. 6 replies.
06-14-2011 3:23 AM
deepseamaster
- Joined on 04-24-2009
- Posts 8
Beovision 10 - Freeview HD (DVB-HD/DVB-T2)
About to buy a beovision 10-40 but before I do, does anyone know if the tuner in the 10 is compatable with Freeview HD, have seen something about an update on the B&O website but not sure if that will make it compatable with the UK HD Freeview?
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Beovision 10 - Freeview HD (DVB-HD/DVB-T2)
Yes it is - all new BV10s are now able to receive Freeview HD.
Jackplug
- Joined on 07-31-2007
- UK
- Posts 83
Hi, my BV10 was new in Dec last year, will it be capable or will I - can I get it upgraded to receinve Freeview HD? Where on the B&O site is the info or link ? TKS
Jack
BV10(40) BV8-32, BV3-32, MX7000, DVD1, HDR1, V8000
Beomedia-1, BS9000, BC7002, BC2300, BS5500, BM6500, BGCD6500, BM1900-2
BL5, BL8000, BL6000, BL Penta3, BL3500
Beovox MC120.2, 3000 Panels, CX50s, C75s, AND LOTS WIRES, BOOkS, MAGS n BITS (ebay sales: beo-store-uk)
Jackplug
- UK
- Posts 83
OK, I've found it now, just need to stand on my head to find out where to insert my USB stick Ooo errr Missus ;-)
On the underside of my BV10 that is...
Jack
csmager
- Joined on 05-09-2008
- Posts 213
Are you sure? The Spec lists DVB-T, and Freeview HD is DVB-T2. It's not backwards compatible.
Jackplug
- UK
- Posts 83
No I'm not sure, but I did not start the thread and thus the title of t, just added my question to it. I'm aware from my dealer that there was a problem with the DVB HD receiver in BV10 because the regulator changed the system for UK HD at the last minuted and thus B&O were "caught out..." I was told there may be an update released idc so was just guessing that this was it. I was just assuming therefore that the problem was just a UK issue? Is there a wider EU issue? I will simply ask my dealer to sort it out, TV is only 6 monts old so still under warrantee. I'll let them take all thre risks in updating it.
Jack
Flappo
- Joined on 05-22-2010
- Posts 168
You can blame the wonderful BBC for a lot of the problems with HD tv , particularly fressat HD. They changed the transponder to DVBS2 from DVBS without actually informing anyone last week.
Typical.
Page 1 of 1 (7 items)
