1st March February 2012
Latest post 08-02-2011 1:18 AM by Leslie. 24 replies.
06-12-2011 6:23 PM
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Glas panel Beomaster 3500/4500
As lots of other people I'm looking for a glas panel Beomaster 3500/4500.
So if there is no other alternative then buying a 2nd hand Beomaster the problem still remains (still missing a glaspanel
Has anyone ever bought this alternative panel on Ebay and can you tell me a bit more how this looks like, is it entirely black (no see through)?
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Re: Glas panel Beomaster 3500/4500
Its about time someone tried to fashion replacements!
After reading about it, I'm not so sure I would be happy with it though. No printing/unmarked, lights barely show through....
Leslie, with the work I've seen you do recently - I know you could do much, much better.
Leslie
- Netherlands
- Posts 2,201
Hi Evan, I almost would say that this option is better then staring at a PCB board
Even though I think I will give it a try. Have asked this question to the seller as well. Read somewhere that if I'm gonna let this panel be laser engraved (for the text) it will become white (on glass). A guy called Barrie on this forum was trying make such a panel a well but I can't find the thread....
Leslie
- Netherlands
- Posts 2,201
Thanks, I'm in there as well
Evan
- Ohio | USA
- Posts 2,601
Leslie:
Yes, if nothing else were available this is a great option. Ever since I refurbished my 4500 system, I've come up with several ideas for it. Thankfully, I don't need to worry about it though, I have an intact glass.
Leslie, I hope you are assembling some sort of reproduction catalogue with all this work you have done recently, it would make a good business!
Leslie
- Netherlands
- Posts 2,201
Thanks Evan! I saved all my refurbishing pictures so maybe that would be an idea!
I'm trying to find another option to replace this panel. Already made the CAD drawing
Leslie
- Netherlands
- Posts 2,201
Btw, seller confirmed that the panel is entirely black. (solid black??).
Evan
- Ohio | USA
- Posts 2,601
Leslie: that would be an idea!
I mean a catalogue of parts to sell! That way I can get some!
I think a piece of glass that has been stained black would be useless. For the sources all you would see (sort of) are red and green squares...
I think you could come up with a way better solution!
Perhaps masking off spaces for the light squares to show through and making small coverings for the source lights (squares) with the source names and such.
DIY Leslie!! I'll help you
Leslie
- Netherlands
- Posts 2,201
Working on it Evan. Already finished the CAD drawing.
First I'll try to source a glas panel. I have lots of perspex plates at home so maybe I try it on them first.
Leslie
- Netherlands
- Posts 2,201
Does somebody knows how this grey material works what you see around the touch "buttons" on the back of the glass panel.
This stuff should touch the rubber pins on the PCB.
Is it a sort of conductive material and if yes what does it conduct to the rubber pins, heat or electricity? What can I use nowadays to simulate this material. Is there anything on the market?
Leslie
- Netherlands
- Posts 2,201
That makes sense Evan, but what happens through the glass when touched by the finger on the other side?
Leslie
- Netherlands
- Posts 2,201
I measured the surface with an Ohm meter and it has a range from 200 ohms to 2 K. So it's an electric conducting material. That I can understand but what makes it active by just touching the glas on the other side? Interesting question?
Leslie
- Netherlands
- Posts 2,201
Something like this you mean?
Leslie
- Netherlands
- Posts 2,201
This would be better
I'm a bit concerned about the touch part of the buttons. Let's see if that works!
Will keep you informed...
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Leslie:
THIS will work fine. Also good for repairing the contact sheets on early Beolinks
Chris.
Leslie
- Netherlands
- Posts 2,201
Bought these already Chris, hope that's what I need! Thanks anyway...
Medogsfat
- Posts 4,045
I cannot see any reason why that wouldn't work Leslie.
Chris.
Leslie
- Netherlands
- Posts 2,201
Medogsfat:
Chris.
You're right Chris! Received the bottle today and tried it on a piece of glass which has been painted black first.
And it really works! Next step will follow and that will be the mirrorized text engraving on the back side...
camshaft
- Joined on 04-16-2007
- Pennsylvania, USA
- Posts 575
Leslie, the touch system is quite simple. It uses capacitive change to register your touch. The grey squares on the back of the glass are simply conductive graphite (I suppose painted on). The rubber peg is also conductive. when you touch the glass, your finger and the mica pad form the two "plates" of the capacitor, with the glass serving as the dialectric. I had thought about how one would make replacement panels also, but as I haven't needed them I never bothered to look too far into it. My basic plan though would be something like doing a thin black paint spray on the back. Then make a simple autocad file that a laser engraver could use to burn off the words in the black paint. Then use a letter silk screen to put the white paint words on the glass, or just pay a silk screening company to do it.
Best of luck, Austin
Edit: Sorry, didn't see your other thread where you already noted how they work.
-Austin (resident audiophile skeptic)
Leslie
- Netherlands
- Posts 2,201
Austin, you're clear explanation is excellent, thank you for that, and now I finally understand how it works. At that time I wasn't sure in which order to work but now I do. Saves me time for the next other panels!
Greatly appreciated!
Page 1 of 1 (25 items)
