I finally got around to having a go and changing the options and now things have worsened! Now when I press 'CD' or 'Radio' - both BS9000 and BC2 will switch on but no sound coming out the speakers at all! I don't know if during the process, I have completely messed up all the option setting.
So basically my set up is:
Main room:
- BV9 - All speakers connect to it
- BC2 - connect to Beosystem 3 via masterlink; also has external speakers connect to aux output
- BS9000 - connect to Beosystem 3 via Masterlink
Link rooms:
- Various speakers and TV connected via masterlink
The problem now is, I don't know if I have changed the options on the BV9, BC2 and BS9000 properly. When I did it the first time, all the devices remained on standby and I simply stood very close to the device and changed the option settings. When it didn't work, I tried to isolate setting each device by disconnecting the other 2 devices from the main power as I am changing the options e.g. when changing A.opt on BV9 it's on standby whilst BC 2 and BS9000 are disconnected. So I believe, currently the options are set as:
BV9 - A.OPT 1
BC2- A.OPT 0
BS9000 - A.OPT 1
But when I press e.g. 'CD' - both BC2 and BS9000 will come on, the CD on BS9000 starts playing and the BC2 will also display the track BUT the main room speakers will not come on. I played around and added 'AV' to my Beo4, and when I did that, the speakers come on. It seems like I have now made the main room speakers, which is connected to the BV9, like link speakers (??).
I am very frustrated at myself, as previously the problem was relatively minor, and now everything is totally messed up!
My concerns are:
1. Is the procedure of disconnected the other devices from the main power correct in order to change the .OPT of each device separately? And when you switch the devices back on, does the previously set .OPT gets set back to default again and that's why the system is not working?
2. Are my chosen option settings correct at all??
3. Does V.OPT on the BC2 and BV9 has anything to do with the problem? Not sure I might have messed up that too.
It seems like the audio component (i.e. BC2 and BS9000) of the main setup has now become separated from the rest of the setup.
Please experts on Beoworld help me!!!!!! At least I just want to revert things back to how they have been! :(
