Hi Workbenchers!
I just restored a Beomaster 6000 output stage (right channel burnout). After replacing the four main IC's and putting in new trimmers on both sides, I decided to fire it up on the bench separated from the BM using two regulated power supplies. After spending about three hours to figure out that one needs to connect the ground leads of the main power plug and the two signal plugs (i.e. P34 to P32/31) in order to have the correct voltages on the DC network of the entire circuit (oh the joys of learning something new...;-), everything seems to work properly. I adjusted the no-load and offset currents to specifications. Now each of the channels draw about 0.18A at ±50V. So far so good! Letting it run for some time, I noticed that the two power transistors on each side (TR210/110 and TR211/111) get pretty hot. All four reached about ~62±5C after 10 min, i.e. they felt quite hot to the touch. By then the temperature remained stable, though.
I was wondering if this is allright, or if I missed something??....(I did exchange all electrolyte caps, and ,remarkably, two 1/2W resistors R155/255 that were both OC and had burn marks on them - got to love ebay purchases labeled "was not able to test"...;-).
Thanks much in advance!
Rudy
