I just brought a Cona. Yum, that thing looks cool. Now to find CX50s or 100s to use in my living room. I have a few questions though:
1. Is there any benefit to pairing a Cona with speakers other than the CX range? I currently use S45.2 and RL60.2
2. If I am using it with other speakers, is there any benefit to connecting the Cona to the speakers 2 and leaving my regular speakers on speakers 1?
3. Do I have systems that will make the most of it (Beosystem 3000 (inc. CDX), Beocenter 9000)?
4. Is there any thing I should check/service on it?
As you may have guessed from my questions, I quickly attached it to the speaker 2 out on my Beosystem 3000 + S45.2, but did not really hear much difference. I know that is not by the book and I should run in series with CX range, but I just wanted to try it out pre CX purchase.
Thanks for any advice.
