Latest post 07-22-2011 8:11 AM by Rich. 32 replies.
Page 2 of 2 (33 items) < Previous 1 2
  • 06-27-2011 6:07 AM In reply to
    Re: BM4000 Down!
    I hope you are back in audio heaven soon my friend
  • 07-21-2011 11:09 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    The BM4000 was received back from the shop on Tuesday, and I have now integrated her back into the system.  Also integrated into the system are the BM4000 Tape 1 switch and a new (to me) BG3404.
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 07-21-2011 11:12 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Re: BM4000 Down!
    I haven't done any serious listening to the BM4000 yet, just the typical "make sure stuff works" listening everyone does on setup.  So far everything seems great!
    This weekend I plan to work a bit on the BG3404, and try out my new SMMC20EN.  That will be the time for some serious listening.
  • 07-21-2011 11:16 PM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Re: BM4000 Down!
    I am very happy to report the "Tape 1 Switch" I built based on the old parallel printer switch works like a charm!  No background noise, no crosstalk, and the ability to record to both tape decks.  Just waiting on receipt of an outboard preamp to add the RX 2 into the mix as a second turntable (you know, for the crappy records that you don't want your new Soundsmith cartridge to touch!).
  • 07-22-2011 6:35 AM In reply to
    Re: BM4000 Down!
    My God !
    I think the last time I saw that was in Bletchley Park :-)
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 07-22-2011 7:30 AM In reply to
    Re: BM4000 Down!
    Hi Rich,
    congrats to your BM4000 being back.
    Looks like it has a dial up to 108MHz (counting the numbers on the printing). Is this true?
    I've newer seen a BM4000 up to 108 while some of the BM3000 do. Surely a US-model then?
    What kind of FM antenna connector is it; the round 75Ohm or the 2-spade 240Ohm? My BM3000 / 108 has the 240Ohm only while the 104 ones have the 75Ohm one only.
    So happy listening; I have one yet to fix as it has a temporary fault suddenly playing loud & treble only on one channel. Resoldering helped but still faulty sometimes. Otherwise yes it sounds great.
      Gunther
  • 07-22-2011 8:04 AM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Re: BM4000 Down!
    elephant:
    My God !
    LaughingLaughing
    "Steampunk" was the vibe I was going for, for better for worse.  Need a different knob I think, but the lettering is perfect.
  • 07-22-2011 8:11 AM In reply to
    • Rich
    • Posts 1,089
    • Gold Member
    Re: BM4000 Down!
    hemenex:
    Hi Rich,
      Gunther
    Yes, US model to "108."  107.9 is the official high end of the US FM dial.  My BM4000 has the round 75 ohm (which I'm using with a simple folded dipole) and the 2-spade 240 ohm.
