Latest post 06-23-2011 4:14 PM by w5bno123. 7 replies.
Page 1 of 1 (8 items)
  • 06-09-2011 6:49 PM
    • mpijl
    • Not Ranked
    • Joined on 11-19-2008
    • Posts 15
    • Gold Member
    Beo4 (type 1710)
    Hi
    I've a new Beo4. For an older BV I need the V.SETUP button, but can't find it.
    Please help. Tx.
  • 06-10-2011 4:16 AM In reply to
    Re: Beo4 (type 1710)
    Hi there
    The features are listed in different sub sections on the remote once you have pressed; Standby and LIST together, ADD? appears, press GO then you can cycle through AV, CNTL etc by pressing list or up/down with the new cursor. It should be listed under AV.
    W5BNO
  • 06-11-2011 3:59 AM In reply to
    • mpijl
    • Not Ranked
    • Posts 15
    • Gold Member
    I tried ADD? and AV? but V.SETUP doesn't seem to be there. Running Beo4 in Mode2.
    Thanks for the advice, but any other suggestions.
  • 06-11-2011 4:07 AM In reply to
    I tried mine too and it's not in the list! Why do you need it for your bv1?
  • 06-11-2011 8:28 AM In reply to
    I tried mine. V. SETUP is present under AV. New Beo 4.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 06-11-2011 9:53 AM In reply to
    Hi I have sussed it! When you go into Menu via Standby and LIST scroll through to CONFIG and VIDEO? appears press GO and then change to 6. Press BACK to come out of menu to ADD? again and it will appear in the list.
    Regards
    w5bno123
  • 06-22-2011 4:25 PM In reply to
    • mpijl
    • Not Ranked
    • Posts 15
    • Gold Member
    Hi w5bno123
    Thx. This works, indeed!
  • 06-23-2011 4:14 PM In reply to
    Your welcome! Don't get asked for that feature much these days!!!
