Latest post 06-09-2011 7:47 PM by futurist. 3 replies.
Page 1 of 1 (4 items)
  • 06-09-2011 5:36 AM
    Ouverture Plastic Panel
    I'm after the right hand (facing the unit), glossy black plastic panel which sits behind the glass doors of the Ouverture. I broke one of the clips removing mine.
    Anyone have one?
    Cheers
    Stuart
  • 06-09-2011 1:43 PM In reply to
    Re: Ouverture Plastic Panel
    These are not too expensive from Bang & Olufsen - I once painted mine white and decided I didn't like it so bought some new ones!
    Worth calling for a price!
  • 06-09-2011 5:58 PM In reply to
    Bought one new for approx. 28 euro
    3162319 Cover black right (for Ouverture/BC2500)
    Think you should still be able to put them back in place with one clip missing?
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 06-09-2011 7:47 PM In reply to
    I'm waiting for the new laser, so the Ouverture's in bits at the moment, but the broken clip is at the top and I think the panel won't sit flat when I reinstall it. But maybe it'll be okay!
    Otherwise, new could be the way to go. Thanks for the advice.
    S
