Just received my Beolab 8000 today. Sadly I tried new transporters which was a bad idea!!
The lid on the Beomaster has broken off. From what I can see its the plastic bit the slids onto the alumium lid that has broken and is in pieces. The hinge itself is fine and works. There are bits left in the groove of the beomaster lid but not enough to stay on. I'm not sure how it actually works or stays on. If anyone has any ideas or maybe even some of the plastic bits that fit into the groove I would appreciate it. Otherwise the system is mint.
Ben
