Latest post 06-15-2011 2:02 PM by hfat. 8 replies.
Page 1 of 1 (9 items)
  • 06-06-2011 5:42 AM
    Does a Beosystem 2 work with Beomedia or Beoport
    Hello@all,
    Has anybody such a configuration. I use a Beosystem 2 9416 (MKII) Software 16.2. Sould it work?
    BR,
    stampfki
  • 06-06-2011 11:21 AM In reply to
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    Re: Does a Beosystem 2 work with Beomedia or Beoport
    I've used one with a beomedia 1 and it is fine - connects via the VGA in port and 3.5mm to phono.
  • 06-06-2011 11:49 AM In reply to
    frog:
    Beoport does not have a VGA port ... do you mean the USB port ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 06-06-2011 4:18 PM In reply to
    • tompa
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    Not beoport, he have a beomedia1, beoport have no picture only audio, but you need a audiomaster that support n.music/n.radio
  • 06-07-2011 5:41 AM In reply to
    frog:
    Thx for your answer. Is it really the same version of the Beosystem 2? Does it support the PC command?
  • 06-07-2011 9:05 AM In reply to
    • frog
    • Posts 191
    I used both  Beosystem 2 versions 1 and 2 with no problem with Beomedia 1 through the VGA input and allocated that to the PC button on the Beo4 remote - and I can't think why anything would be different with version 3 of Beosystem 2.
    Note that this only works for the screen connected to the Beosystem 2 - not for linked TVs.
  • 06-15-2011 4:28 AM In reply to
    Please, could anybody check his Beosystem 2 software to compare it with my software revisions (see att. photo)?
    I would appreciate your help.
    THX
  • 06-15-2011 12:46 PM In reply to
    • hfat
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    hallo,
    mein BS2 hat folgende Versionen:
    SW 16.0
    SW 22.0
    SW 3.6
    Table 4.19
    EEPROM 050
    Type 9421
    Bei mir ist auf allen Anschlüssen die Quelle PC verfügbar. Bei Decoder zusätzlich PC(DVI) und Camera zusätzlich PC(VGA)
    Grüße hfat
  • 06-15-2011 2:02 PM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    hallo,
    Ich glaube BS2 MKII kennt noch kein PC Command. In diesem Fall muss man das BM1 an einen Scart-Anschluss des BeoVision anschließen. Zur Steuerung benötigt man allerdings ein zusätzliches IR-Auge.  Am Besten wird es als Quelle V.Aux definiert. Ist dann allerding nicht link-fähig. Den Masterlink-Anschluss benötigt man dann nur, wenn ein N.Music-fähiger Audiomaster im Einsatz ist.
    hfat
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
