Latest post 06-11-2011 3:12 AM by stotty1111. 6 replies.
Page 1 of 1 (7 items)
  • 06-04-2011 10:29 AM
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    Where can I get a piece for my MX motor stand?
    The motor stand for my MX4002 is missing a couple of pieces - the "plug" which goes in the bottom of the main upright support, and the cover for the wiring channel. The helpful guys at B&O in Bournemouth have tried to help me find a "plug", but without success. Can anyone here suggest where I might obtain either part?
    I need the "plug" in order to spread the weight of the TV on a soft vinyl surface, as the sharp edges on the bottom of the upright could damage the vinyl.
    I've tried to attach a picture, where the "plug" is part 9187 and the channel cover is part 9184. If I fail to attach the picture, I'll follow up with another email to provide it.
    Basically - the channel cover is a "nice to have", but the plug is rather important!
    Mark
  • 06-04-2011 11:45 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Where can I get a piece for my MX motor stand?
    I might have both bits, recently picked up a tv with a stand etc - unfortunately its near Clows Top and i'm in France - i return uk in 2 weeks pm me for location etc if theyre there you're welcome!
    I'll look here as well as I have some bits and pieces here i finistere
    salut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 06-04-2011 5:45 PM In reply to
    • deaddruid
    • Posts 247
    Thank you, Tony. Seeing you list Worcestershire as one of your many locations, you must be (almost) a neighbour!
    Mark
  • 06-05-2011 2:55 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Lived on Fruiitlands many years ago, at the side of the tunnel entrance -
    have found some bits here in France, what diam is the plug you seek, also the length of the filler piece may be having a hairdresser nmoment but seem to remember different sizes etc!
    salut
    t
  • 06-05-2011 5:24 PM In reply to
    • deaddruid
    • Posts 247
    Ah! The posh end of town!
    Sadly, I can't get to the TV until Wednesday, so I'll try to measure it then. It's not a whole circle, but has a slot cut into it.
    Mark
  • 06-10-2011 3:45 PM In reply to
    • deaddruid
    • Posts 247
    The "plug" seems to be about 9cm diameter, whilst the channel seems to be about 20cm long.
    Mark
  • 06-11-2011 3:12 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Mark
    Found both pieces - the plug is a little bent but should flatten with the stand weight on it - its quite pliable!
    I'll pm you later today/tomorrow with more dtail etc
    Salut
    T
