I just wanted to share my experiences of fixing a power supply problem with a Beocom 4. Other posts suggest that this may be quite common.
My Beocom 4 developed an intermittent power supply problem that I eventually traced to the connection between the charging cable and the plug in charger. I initially thought the cable had a break in it, hence got a quote for a replacement charger - £35!
Whilst trying to take the charger apart, I realised that by twisting the cable/charger connection by 90 degrees it actually detaches from the charger to reveal that it is connected with a standard DC plug connection - like the one used for mobiles. I undid the single screw under the charger and used a bit of brute force to pull it apart. Upon pulling out the small circuit board it was immediately apparent that the surface mounted DC socket solder joints were dry/disconnected. Ten minutes with the soldering iron, reassembly, and all is now working perfectly.
Hope this is useful!
